Novatec D462 hub an...
[Closed] Novatec D462 hub and freehub bearing change help
[#9692291]
Anyone taken apart the above hub and can offer any help on "how too"??
I've had a quick look and been on the web looking but can't find anything definitive. It all seems to be road hubs.
I guess the first question should've been are they servicable/
TIA
Carlos
Posted : 28/11/2017 3:42 pm
The 772 axles on ebay are listed as being compatible with 462: they are made of two parts that screw together; the QR ones probably have hex shaped holes on both sides?
Once you unscrew the axle, I assume you should be able to pull the freehub out.
Posted : 28/11/2017 3:57 pm
Thank you.
That's a good start and the first thing to try once I've brewed up
Posted : 28/11/2017 4:07 pm
Well that went well.
Took all of about 2 mins to take apart, good clean and rebuilt in under 30 mins. Got a list of bearing No's too
Posted : 28/11/2017 9:25 pm
Have you the bearing no’s for this?
Posted : 01/04/2018 11:03 pm
Have you got the bearing no’s for this?
Rear hub & Freehub
2x 6902RS
1x 6809 LLUMAX
1x 15267RS
Posted : 02/04/2018 11:37 am
