"Northwave Cel...
[Closed] "Northwave Celsius GTX" Sizing
[#4452683]
Can any one tell me how these shoes come up in the sizing department? Did you need to buy a size up from your normal shoes or do they come out about the same?
Posted : 12/10/2012 5:04 pm
Mine are a couple of years old now but i had to go up 1 size, i'm usually a euro 44 but have a 45 in the Northwaves and they fit fine.
Posted : 12/10/2012 5:27 pm
I'm normally a 45 and I bought a 45 in the Northwaves. they fit perfectly 🙂
Posted : 12/10/2012 5:28 pm
I found them to be fairly normal, although I'd still go to a shop as the shape was unusual, I ended up about 3 sizies smalled than the first pair I tried on. Initialy assumed I'd be 46 as I'm 44/45 in spesh as i wanted room for thick socks, then ended up in a 44.
The toe is quite narrow, but it seems to be longer as well so normal feet just sit comfortably further from the end. And I have wide feet.
p.s. get the artic version, £10 and can get away with normal socks through most of the winter.
Posted : 12/10/2012 5:31 pm
I'd recommend trying the actual boot, having sized up another shoe in their range prior to ordering the boot, I couldn't even get into it when it arrived.
Posted : 12/10/2012 7:17 pm
