Nobby Nics 2.35 wha...
[Closed] Nobby Nics 2.35 what they like size wise?
[#1030735]
As title really, just wondering if anyone can measure, or know, what they're like pumped up on a wheel, the width obviously (before I get someone saying 'it's 26 inches' or sumfink) as I want to check the clearance on my older frame? Do other Schwalbes tend to come up large or spot on for sizes?
Cheers 🙂
Posted : 11/11/2009 1:02 pm
mine come up narrower, more like a 2.1
Posted : 11/11/2009 1:06 pm
I've just stuck one on my hardtail. It definitely looks wider than the Maxxis HR 2.3 I took off.
Posted : 11/11/2009 1:07 pm
these are huge......they come up big!
There is no NN 2.35, you can take you choice between the 2.25 which is like a largeish 2.1 or the 2.4 which is more like a 2.35. They are also very pressure sensitive, too much and they bounce around, too little and the thin sidewalls flex lots.
Posted : 11/11/2009 1:14 pm
ah mine will be the 2.25s then.
Posted : 11/11/2009 1:26 pm
Ah, typo 😳 I meant 2.25 ... so more like a 2.1 then, should be ok for my older frame, although would appreciate it if someone could measure it just to make sure?
wheelz, you must have the 2.4 ?
Posted : 11/11/2009 1:41 pm
No, I've definitely got the 2.25. They measure 60mm across the width at 35PSI, which is the same as the HR 2.3 I took off. Just measured both now.
Posted : 11/11/2009 1:54 pm
hmmm thats strange. just mesured mine, pumped up to 30 or 35, and theyre only 50mm across.
im running mine ghetto tubeless, but cant see that making a difference?
Posted : 11/11/2009 2:13 pm
Could be the rims. I'm running mine on Mavic XC717 disc rims.
Posted : 11/11/2009 2:27 pm
mine are mavic 317s
Posted : 11/11/2009 2:51 pm
Then it is most probably my dodgy measuring technique. Shall we compromise on 55mm? 😀
Posted : 11/11/2009 3:37 pm
On my diggy venier gauge mine are 54mm on 717 rims 🙂
Posted : 11/11/2009 3:42 pm
55mm on mine at their widest - 717 rim
Posted : 11/11/2009 3:43 pm
Brilliant, 55mm seems to be the consensus for the 2.25 then, I'll measure up my frame later...
Thanks 😀
Posted : 11/11/2009 4:16 pm
