Nobby Nic / Hans Da...
[Closed] Nobby Nic / Hans Dampf combo
 bgd
[#6002751]
New bike came with Nobby Nics as standard, while the rear is fine I have absolutely no confidence in the tyre on the front.
Had a go on a mates bike with Hans Dampf front and rear and was very impressed. Does anyone run a Hans Dampf front, Nobby Nic rear combo and rate it?
Posted : 02/03/2014 2:13 pm
Yes. On my PYGA. 2.35 HD front and 2.25 NN rear, tubeless. Works for me, on this bike. I use other combo's on other bikes.
Posted : 02/03/2014 2:19 pm
I run Hans Dampf / Racing Ralph combo. It works perfectly. The a racing ralph keeps the back nimble and loose and not at all dragging on fire roads. The Hans Dampf cling like nothing else and provides a grata safety net.
I switched to this from nobby Nics front and rear which I had run many times before but never had huge confidence at the front,
Posted : 02/03/2014 2:20 pm
 Alex
I ran that on my FS 29er. Thought it was a good all round combo. Still pretty fast rolling, plenty of grip on the front. Ran tubeless from the off and had no issues on rocky trails. Rear NN always felt a bit squirmy compared to the front, but definitely a good all-year compromise.
Only switched when the DHF became available for the 29er.
 bgd
Cheers all, sounds like a plan.
Posted : 02/03/2014 2:24 pm
I found HD carries too much mud to be a viable UK winter tyre. Spesh Storm Control is doing it for me. Nic on the back is fine.
Posted : 02/03/2014 2:45 pm
Sorry I mean Butcher Control 2.3 not Storm Control.
Posted : 02/03/2014 2:48 pm
I run that exact combo. Overall am pretty pleased with it. Will change to HD rear for alps or racing though as NN can be a bit fragile
Posted : 02/03/2014 4:35 pm
Just get a pair of PaceStar HD's - problem solved.
Posted : 02/03/2014 6:24 pm
I tried that HD front NN rear combo, set up tubeless. I was less than impressed with the grip on the rear on rocks and roots so I wasn't too upset when a knob tore off the NN on the fourth time using it leaving a 1cm split in the casing and Stans jizz everywhere. The grip issue may have been due to using the harder Pacestar compound though. I then put a Maxxis 3c High Roller 2 on the rear. I found this gripper but draggier than the Nobby Nick, and maybe I'm wrong but draggier even than the Hans Dampf I had on the rear before the Nobby Nick. A Hans Dampf is going back on the rear when the hr2 is worn and I'll just put up with the rapid wear.
Posted : 02/03/2014 9:48 pm
Do you know what compound NN's you've got?
Posted : 02/03/2014 9:50 pm
Almost exactly the same experience as sodadr
I wasnt too bothered about the lack of grip with the nn on the rear as they were fast but when the sidewall tore I went back to the draggy hr2 , might try an ardent or a smorg on the rear- when 650b ones out
Posted : 02/03/2014 10:18 pm
