Newbie Disc user - ...
[Closed] Newbie Disc user - Changing up a size rotor ??
[#1994685]
Numpty question here as I've only just got a bike with discs 😳
If I want to put a 180mm rotor up front instead of the 160 fitted, is it just a case of changing the caliper mount to a post to IS 180mm mount ??
Posted : 15/09/2010 4:56 pm
Depends on the type of caliper and fork - but if the calieper is post mount and the fork IS mount then yes
Why do you want to do it tho? Is it really needed?
Posted : 15/09/2010 4:58 pm
Yes, if you've got new(ish) calipers that are post mount, with a removable mount to fit them to the fork, then just replace this with the larger 180mm equivalent IS to post mount (or if you have a rear 160mm one knocking around they do the same job on the front!).
Posted : 15/09/2010 4:59 pm
