New rotors, old pad...
New rotors, old pads?
[#13269783]
Have replaced my rotors on my commuter as they were a bit thin when I finally had a look. Plenty of meat still on pads I replaced not so long ago.
Do I need to use new pads too or is it ok to re use the old ones?
Posted : 28/05/2024 7:50 pm
New pads
Posted : 28/05/2024 7:56 pm
For a hassle free experience, new pads.
If the rotor has worn to a uniform thickness you'd probably be OK with the old pads, but I'd scuff them up with sandpaper.
If the rotor has worn so it's thinner in the middle (which normally happens) then 100% new pads time. The pads wear to match the rotor shape, hence, the pads matched to a worn rotor will 'bulge' in the middle. Installing a new rotor will mean that only the middle of the pad will contact the rotor. At best you'll have poor braking for a while. At worst the pads will glaze over and howl, and have poor braking. Well, at worst you'll get hit by a bus....
Posted : 28/05/2024 8:01 pm
Thought so - was trying to be frugal. New pads it is.
Thanks
Posted : 28/05/2024 8:23 pm
I've never had a problem with used pads and a new rotor.
Posted : 29/05/2024 12:41 am
reeksy and reeksy reacted
Same
Posted : 29/05/2024 2:13 am
Yeah I'll happily mix as long as the pads are in reasonable shape
Posted : 29/05/2024 4:34 am
Never had a problem using old pads
Posted : 29/05/2024 6:19 am
Use the olds ones, replace with new if they aren't liking the new rotors for some reason.
Posted : 29/05/2024 8:05 am
Use a Stanley blade at 90 degrees to the pad and scrape the surface, then reuse, works far better than sanding.
Posted : 29/05/2024 8:09 am
 mert
If they are in reasonable/good condition, just reuse the old pads, i've always done that.
Just need to do a few good hard stops, which you'd be doing with new pads or rotors anyway.
Posted : 29/05/2024 8:28 am
