New Hope Hoops maki...
[Closed] New Hope Hoops making a "tinging " sound
[#1911611]
Just fit a front Hope Hoop with a Stan Crest rim. When i fitted the tyre (tubless) and did the Stans wheel dance the spokes we're making a Tinging noise. I've now fitted the wheel to the bike and when test rode around the garden as i turned the wheel made exactly the same sound on each turn.
the spokes on one side make a slighty low sound when flicked with my finger nail than the other.
Is it safe to ride?
Is it just the wheel bedding in ?
Opinions please.
Posted : 19/08/2010 5:25 pm
spokes beding in. no problem. might want to check tension in a few rides.
Posted : 19/08/2010 5:28 pm
 thv3
Yep, spokes settling in.
Check them in a couple of weeks once everything has settled down.
Posted : 19/08/2010 5:34 pm
Spokes shouldn't need bedding in after it's been built - they're supposed to be tensioned when building
Posted : 19/08/2010 5:37 pm
spokes sligthly twisted from build when tensioned up which is normal/usual- who built it? moan at them they should have got this out before giving to you.
Lie wheel down on skewer/hub and put gentle ish pressure on rim at opposite sides and rotate + repetill it stops.Tension should be largely unaffected by this as slight loosing effect only.
Poor wheel build /attention to detailIMHO.
[url]uplink - Member
Spokes shouldn't need bedding in after it's been built - they're supposed to be tensioned when building [/url]
Yep thats the theory, but IME the noise he's hearing is them bedding in (properly) and they'll stop doing it after a ride or two. Though mine have never need retentioning due to this.
Posted : 19/08/2010 5:40 pm
I'd go along with what ZIppy mentions.
My hopes went through the same phase for a ride or two and seem to be all good so far.
Posted : 19/08/2010 5:44 pm
They shouldn't ping at all
Should`nt keep bedding in for a ride or two! When wheel is built spoke tension, twisting, should have been relieved by stressing rim all way around, eg by putting on floor and pushing down on rim; this gives spokes a chance to bed in and unwind any tension or twisting. IME any wheel pinging has only lasted a few wheel turns before stopping. I have had 2 pairs of Hope Hoops, 1 MTB and 1 road 700c; neitehr pinged at all on first ride or thereafter.
Posted : 19/08/2010 5:45 pm
Only wheel recently that I've had that "tinkled" was a 700c from Ribble, needed a retrue after first weeks use.
Posted : 19/08/2010 5:47 pm
Maybe not but I'm with zippy, mine did the same for the first ride and no probs since (few years ago now).
Posted : 19/08/2010 5:53 pm
thanks for the reminder to do mine 😉
Posted : 19/08/2010 6:05 pm
Junkyard,
they are factory hope hoops with Crest rims from Winstanleys.
Right so i need to remove the wheel , rest it on its 20mm adapters and gently apply pressure to the rim and slowly work my way round the rim. Am i correct.
I have got these wheels on my other bike and haven't had this issue. So just wanted to check i wasn't going to meet the Grim Reaper on my next ride.
Posted : 19/08/2010 10:18 pm
Yes! Do what you said!
Posted : 20/08/2010 10:07 am
this is normal.
wheels that don't ping are v. well made. mine all do this but i am to wheel building what scrapheap challange is to enzo ferrari!!
Posted : 20/08/2010 10:11 am
Nope just ride em - enjoy 🙂
Posted : 20/08/2010 10:12 am
Yeah. You could do that....
Or just ride it for a bit.
Posted : 20/08/2010 10:13 am
so i've had a wheel (12 year old hope ti glide on 521 rim for two years) and i've just got this pinging sound too! wheel is true, only thing is i've just put a new tyre on (2-bliss spesh captain) pumped hard so wonder if this is it?
Posted : 20/08/2010 3:10 pm
Has it got black spokes? If so then there maybe flex in teh spokes and the painted spokes can rub causing a pinging sound?
Posted : 20/08/2010 3:53 pm
Yep , black paint spokes
Posted : 20/08/2010 4:50 pm
