New hoops 2013/14 C...
[Closed] New hoops 2013/14 Carbine
[#8236805]
I'm thinking of getting a new set of wheels for the above (29er) I'd like to put 35mm rims on them and am currently running 30mm. How do I measure if they'll fit?
Intense Carbine 160mm Pike.
Posted : 20/12/2016 9:23 am
 poah
what do your 30mm rims not do that you need 35mm ones? tyres aren't going to be much, if any wider on 35mm rims and the profile will be shit. Very few tyres are designed for wide rims.
Posted : 20/12/2016 10:24 am
TBH I'm just replacing them to tart the bike up a bit.....I'm probably going with Nexties,just don't want to do the measuring thing properly before I order.
Posted : 20/12/2016 11:02 am
What Poah Said. If you're running normal tyres then 30mm is about as wide as you can go IMHO. Beyond that the tyres get too exposed and too flat. Also you'll be carrying more weight I expect which is never a good thing. All that said, if you don't mind the weight and run big tyres (regular 2.5s, Wide Trails or small plus tyres) then 35 is a good size. Size wise anything that isnt plus will fit a Pike I have found. But it gets tight for mud clearance on the Wide Trail tyres as they are taller than regular ones.
Normally run Magic Mary 2.4 front and Hutchinson Toro 2.3 rear.
Posted : 20/12/2016 11:11 am
