New Fork Time
[Closed] New Fork Time
[#5343209]
& it's good
[URL= http://i1097.photobucket.com/albums/g341/kiwijohn42/null_zps1e6371ee.jp g" target="_blank">http://i1097.photobucket.com/albums/g341/kiwijohn42/null_zps1e6371ee.jp g"/> [/IMG][/URL]
So long Fox.
Posted : 18/07/2013 1:53 pm
thats going to be hard to see in the snow!
Could be down doing Tangara on 28th too
Posted : 18/07/2013 1:56 pm
New pikes are AWESOME! Charge damper in sids and revelations for 2014 aswell.
Posted : 18/07/2013 2:01 pm
Might be a bit much bike for that Mike.
Posted : 18/07/2013 2:06 pm
Looks epic!
Posted : 18/07/2013 2:08 pm
What's the small bump sensitivity like with the solo air spring?
I'm reluctant to get rid of my dual air revs because I can set the negative spring up to give a bit more plush starting stroke.
Posted : 18/07/2013 2:35 pm
Is that a Rev or Pike? The Stanchions look really skinny in that photo!
Let us know how it feels 🙂
Posted : 18/07/2013 2:52 pm
That is a Pike. You can just about make it out on the sticker on the inside of the leg.
Also has the "murdered out" stanchion coating. I don't think this is on the Rev yet.
Posted : 18/07/2013 3:54 pm
I certainly don't miss the dual air in my old Pikes. These feel spot on.
If they look skinny, the Fox 32s would be anorexic.
Will have a lot of ride time by the end of the weekend.
Posted : 18/07/2013 10:04 pm
Hi Kiwi,
I have an SB66 and am thinking about swapping the forks to Pikes.
I currently run 170mm X Fusion Vengeance HLR. They are great forks but too big and too heavy for my needs. The bike is VERY slack.
I am not sure whether to go for the 150mm or 160mm Pikes. I read that the SB66 was originally designed for 150s. I mainly ride at Swinley Forest - which is as much up and along as it is down so Im looking for versatility but I dont want to loose that epic confidence you get when you point the bike downwards and into the rough stuff. Would I loose this with 150s? How do you find the 160s and why did you choose them over the 150s?
Thanks
(bike looks great btw)
Posted : 31/03/2014 10:43 pm
I find your choice of grips abhorrent. Everything else is fantastic
Posted : 31/03/2014 10:53 pm
