Needle roller shock...
[Closed] Needle roller shock bushes- thoughts?
[#4130549]
After replacing my worn shock bushes on my dhx5 air and stumbled across these on the beted website:
http://www.mountainbikecomponents.co.uk/items.asp?CategoryID=231&Name=Fox+Needle+Roller+Bearing
Anybody tried them? Do they offer any performance improvement over std bushes? Also do they last as long ?
Posted : 04/07/2012 1:15 pm
Total and utter waste of time unless the pivot moves upwards of 90degrees, which it wont
Posted : 04/07/2012 1:23 pm
Obviously bland has tried them and so speaks from experience, but I also have them and find they last better on my bike than either the original Fox bushes or the plastic ones whose name I have forgotten.
However, I would say it is marginal whether they last so much longer to justify the extra cost, and I can't honestly say that I have noticed any difference in the suspension action.
Posted : 04/07/2012 1:28 pm
note many gudgeon pins use needle rollers (piston engines) and the angular rotation is only about 30 degrees...
Posted : 04/07/2012 1:36 pm
http://enduroforkseals.com/id275.html
yeah i think they feel better, but i'm very light (hence low pressures) and aware of what suspension is doing.. ymmv.
Posted : 04/07/2012 2:18 pm
and many just use a plain bearing, needles are more common on 2 stroke due to the differing lubrication strategy for 2 strokes. on a 4 strokes with a pressure oil system the oil is the bearing.
needles are good though they are not tolerant of misalignment or grit/dirt
metal backed acetal bushes work well.
for bike shock links doubt you could tell the difference between any types...
Posted : 04/07/2012 4:15 pm
They go rusty and seize unlike a standard bush so I wouldn't bother
Posted : 04/07/2012 4:24 pm
Think I'll order the "bog standard" bushes then. Thanks for the responses.
Posted : 04/07/2012 4:33 pm
 LoCo
Polymer ones are best bet price v performance/wear wise
Posted : 04/07/2012 4:35 pm
