Just need to find time to build it - my Vulture which is donating a lot of parts is filthy, so need to brave the cold and wash it, then dismantle
Got it mostly built, although I discovered that I wasn't given any bolts to mount the front brake... seems Fairlight don't include them, and neither do SRAM, although both included bolts for the rear. Have stuck in a couple of silver dome head bolts I found, hopefully do the trick. I'm bar tape, brake hose shorten/route/bleed and a chopped steerer away from done
Speedy work. I don’t think I’ve ever received bolts with a frame or fork
Would normally come with the brake, though... and they did with the rear brake, just not the front.
Really taken with the top tube, it's incredibly thin.
Yes the tube shapes are lovely. It’s interesting to compare it against @ahsat s Niner RLT also 853
