Narrow HT2 spacers
[Closed] Narrow HT2 spacers
 st
[#1238278]
Has anyone had any success finding bottom bracket spacers for HT2 less than 2.5mm wide? I'm trying to tweak the chainline and get a better fit for an MRP 1x chainguide on my new 456.
I guess these would do (if they had them in stock)??
http://www.chainreactioncycles.com/Models.aspx?ModelID=34981
Posted : 19/01/2010 5:52 pm
Rub one down on some sandpaper?
Might want to watch your fingers though!
Posted : 19/01/2010 5:53 pm
Ohhh good call (the OP not the sanding suggestion), having issue with a new middleburn outer ring & an E-type mech, which this maybe the solution too.
Posted : 19/01/2010 5:55 pm
My HT2 came with a 2.5 , and two thinner ones which added together make 2.5 IIRC
Posted : 19/01/2010 5:58 pm
dont sand them, the cups relly on them being straight
Posted : 19/01/2010 5:59 pm
Did you use them? As the 4 sets I've had only came with the 2.5 versions
Posted : 19/01/2010 6:00 pm
 st
Problem is I only have 1 proper HT spacer. After taking the chainset off a frame with a 73mm shell to a 68mm I've lost the other 2 original spacers. I've fudged a cassette spacer for the non drive side so far and would rather buy a couple of 1.5mm spacers than spend an evening sanding something that I don't have down.
Do new BBs come with spacers? One of the bearings is pretty rough so it may be worthwhile sorting a new one.
Posted : 19/01/2010 6:04 pm
The newer BB's come with two smaller spacers that make up 2.5mm, but it's not a half & half split & one 2.5mm spacer, but can't remember what sizes at the moment.
Posted : 19/01/2010 6:06 pm
Have a look at this:
In the bottom right hand corner, underneath where it says 'When using a band-type front derailleur' the illustration shows a 0.7mm spacer and a 1.8mm spacer.
Posted : 19/01/2010 6:07 pm
