My turn for a “is t...
[Closed] My turn for a “is this a crack or a sticker” thread
[#11742695]
Cleaning up my CX bike for indoor turbo trainer duties and I spot this on the inside RH fork leg, it’s about 40 mm long, I can just about feel it when run my nail over it, it doesn’t go around the leg nor is the leg deformed/bulging in any way. Bike is very under used and never been crashed so I’m hoping it’s just a scratch in the lacquer. I will take it to my lbs/Kinesis dealer when I get chance for them to look at it (not expecting owt from Kinesis, it’s 7 years old now iirc)
Posted : 09/02/2021 12:20 pm
Is there any movement if you press one side of the "crack"?
Posted : 09/02/2021 12:22 pm
That doesn't look good, (even accounting for your terrible photography 😁) it looks like dirt has leached into the crack, which is why you can see it. Probably repairable though.
Posted : 09/02/2021 12:23 pm
No it’s solid
Yeah its a bit hard to get camera in there and for it to focus properly.
I see Kinesis have one of their forks on sale at the moment, I’ll see what the lbs says, for now it’s confined to turbo trainer duties so no rush to sort it out
Posted : 09/02/2021 12:24 pm
<div>from Imgflip Meme Generator</div>
Posted : 09/02/2021 12:28 pm
What a well- photographed chainset! 😝
It’ll be fine for turbo duty, but I’d not ride that without some investigation. Can you rub it back a bit to see what’s underneath? Worst case is cosmetic if you find there’s nothing to it, and some tape would do a good enough job covering that for me if that’s the case.
And if you find something then I’d bin them and get new, I’d not look at repair for forks.
Posted : 09/02/2021 12:29 pm
is the crack in the downtube or the wheel??
Posted : 09/02/2021 12:35 pm
Fork leg - I skimmed over that. No, you're dead right, for the price of a pair of forks vs. the price of a repair vs. the price of a set of teeth, I'd get new forks too.
I’ve called the lbs and I’ll take it to them on Friday. Yeah no chance I’ll get it repaired, I’ll never fully trust it and Kinesis RL02 alloy forks are currently £90 which I imagine would be a fraction of a carbon repair cost
Yup the mark/crack is on (carbon) fork leg
If it is a crack I’m glad it’s happened where the white paint is, I would never have spotted it otherwise which doesn’t bear thinking about
Just to update for a bit of closure
I finally got around to removing the forks with the intention of giving them a going over with some wet and dry to remove the paint back to the carbon. I barely touched them with the paper, just enough to take the lacquer off and the scratch disappeared. I carried on and removed some of the paint just to be sure, I’m happy that it was just a scratch
Posted : 30/04/2021 12:53 pm
Result. Just need to get it repainted now.😉
Posted : 30/04/2021 1:40 pm
Nah he can use a sticker to cover that up 😀
Posted : 30/04/2021 1:47 pm
Posted : 30/04/2021 2:25 pm
