My ball dropped - I...
[Closed] My ball dropped - I can't find it.
[#8471411]
I just serviced my TRP spyres and one of the 6 ball bearings dropped on the floor. I can't find it so will need to get another.
Any idea what size they are? I don't have my callipers to measure them.
If anyone has one available it would be a life saver ( for my wife as they are on her bike 🙂 )
Thanks
Posted : 26/04/2017 1:09 pm
 Yak
It's under the fridge.
Posted : 26/04/2017 1:10 pm
*assuming metal
have you got a decent magnet - if so run it around the floor under stuff etc
Posted : 26/04/2017 1:20 pm
Check your trouser turn ups.
Posted : 26/04/2017 1:22 pm
Sell the wheels then they'll turn up.
Posted : 26/04/2017 1:25 pm
Yak knows the truth. Fridge suck is a very powerful force.
Posted : 26/04/2017 1:28 pm
Must be very powerful to get under the fridge from two floors away.
Done the magnet trick but still can find it on a white tiled floor in the workshop.
Posted : 26/04/2017 1:57 pm
A ball bearing dropped onto a tile floor will bounce quite high. Have you got shelves/racks it could have bounce onto?
drop another one and see where it ends up!
Posted : 26/04/2017 2:43 pm
My* balls measure 0.116" / 2.95mm.
Explains my sedate progress down hills and a reluctance to tackle jumps.
(* Coincidentally, the balls in my TRP Spyres are exactly the same size when measured with a digital caliper. I'm guessing they will be 3mm. I would suggest replacing the set of 3, rather than just one, but you were probably going to do that anyway.)
P.S. I have loads of 1/8" ones which would possibly work if you're stuck.
Posted : 26/04/2017 2:55 pm
Check it isn't wedged in the tread of your shoe
Posted : 26/04/2017 3:02 pm
Better still, chuck the remaining bearings out in random directions to give you an idea of likely hiding places.
Posted : 26/04/2017 3:03 pm
I found a ball bearing - but I was from something else. ( and too bloody big for the spyres.
Tillydog - thank you. That's a great help.
Off to eBay to get some ordered.
Posted : 26/04/2017 4:35 pm
It might be two floors away, but did you check under the fridge?
Posted : 26/04/2017 6:08 pm
