Movement in Shimano...
[Closed] Movement in Shimano SLX floating rotors?
[#2040429]
We are running new Shimano SLX floating, splined rotors on our bikes (180mm & 160mm). Both are a handful of rides old and we have noticed a little movement between the rotor and the spider in the rear wheels. Is this usual?
Posted : 29/09/2010 9:02 pm
Is the clue not in the name?
FLOATING......
Posted : 29/09/2010 9:47 pm
Sure its not just the pads moving back and forwards in the calipers?
Posted : 29/09/2010 10:01 pm
seen this on a few bikes. its a fixed rotor but theres movement in some of them. it can feel like the pads moving in the caliper but a bit more extreme.nothing as far as i know, has been reported and sorted out as yet.
Posted : 29/09/2010 10:30 pm
It's definitely not movement from the pads. But thanks for your responses.
Posted : 30/09/2010 4:58 pm
I had a Hope rotor start moving recently. Tiny bit of rotational movement, could be felt with brakes on & rocking the bike. Just a few degrees, but enough to feel through the levers. Chap at Hope said its to be expected eventually. On his advice I gave the rivets a good squeeze on the Fly-Press at work & have had no movement since.
Posted : 30/09/2010 5:03 pm
