I've nearly finished my retrotastic Raleigh SS road bike and have tried using the wee frame that bolts onto the seat rails and mounts 2 cages and it looks cack
Older bikes had bolt on cage mounts but can I find any.......no......any ideas of what else I could use
Cheers for any help
Ken
If you don't mind drilling your frame(and can do it reasonably accurately), you could fit Rivnuts like most manufacturers use,a good bike shop will probably have a tool for it.
surely cable ties are your friend?
You could try one of [url= http://cyclocrossworld.stores.yahoo.net/twofiswatbot.html ]these[/url] don't know if they are available over here but I have ordered from Cyclocross World without any problems.
Is a bar mounted bottle out of the question?
[url= http://www.decathlon.co.uk/EN/apb-300-bottle-cage-bracket-17250470/ ]This[/url] too naff?
If you were to go for the cheap and cheerful cable tie option, you may find that you need one going to the top tube as well, which ends up looking a bit duff. Works for me at races though.
Cut up an old tube to protect your frame then cable tie the bottle rack. Thats it job done.
I bought one of these in the States [img]
[/img]
It's made by [url= http://www.twofish.biz/bike.html ]Twofish[/url] great product (no connection!) Don't know if they have a UK distributor.
Velcro holds the cage securely to the frame
Corleys do a simple one, like all of the above but with metal straps - worked fine on my old crosser.
Or you could go for the L'eroica look with a couple of bar mounted alloy bottles.
Though actually we just used two metal bands that clamped around the cage in the 60s and 70s, just like the cable clamp/guides all the bikes had, but that's too simple for these days 🙄 I need some for my Claud.
Oldgit
I spoke to Ray at Corleys and he said they'd dumped a load of their old stuff a few years ago as there was no call for it.
It's those old metal bands that I want as I don't fancy bar mounted ones. If I find some how many do you want me to get for you?
I use to use DMR chainguide clamps they were available as a spare at one point .Buy a pair and the bolt hole you mount the chain guide on gets used as a bottle cage mount .It's a nice hinged bracket in alloy it looks very tidy
Ken
Just a pair for now thanks.
