Hi im building a frame up for a mate and i was looking at changing they roller bearings in the lower linkage as the are past it.
Have found a guy who does bushes which seems a good idea but he it is a bit to expensive.
Doeas anyone know if these bearings are available anywhere ? Or anywhere to source bushing material, as i can get it re manufactured in my work.
I think the bearings are supposed to be fairly standard - 688 bearings rings a bell
Take them out and take them to a bearing supplier to measure them up
Alternatively Mongoose do a bearing kit for something like £20-30
The standard set up on the teocali is very poor as far as the linkage is concerned.
I have now killed 3 sets of bearings due to the total lack of a seal to keep the moisture out. Once i get a new set of bolts i will be having the bush conversion done as it is bound to last much longer.
I do have the e mail address for a guy from the forum who will replace the bearings with a bush. He charges £35. This is about the same as a link kit from Hotwheels ( UK distributor).
If anyone need to order a kit or any or the parts here are the Stock and Alternative codes -
Stock/Alt Code/Description
WS00/WS00/Link Body(x1)
MTBMG11/1210/Bearing(x4)
MTBMG14/B341/Hollow Axle (x2)
MTBMG15/B366/Plastic washer (x4)
MTBMG16/B367/Alloy end caps (x4)
MTBMG23/????/Bolt assembly (x2)
The bearings are type HK1210.
