Minimal pad wear bu...
[Closed] Minimal pad wear but excessive lever travel.
[#8396612]
I've given the brakes a good bleed using the shimano yellow plastic block. The problem still persists.
Is the solution to use a slimmer block to move the Pistons further out at rest?
Does it matter that I'm bleeding with the lever bite screw on it's furthest from the bar position?
Posted : 13/03/2017 10:59 am
What model brakes?
Most models have the lever position adjustment, but only the higher spec ones have bite point adjustment, make sure (if you have it) that it is screwed all the way out before trying another bleed.
Lever position adjustment shouldn't make any difference.
Posted : 13/03/2017 11:59 am
Old style deore that can't use the funnel.
Posted : 13/03/2017 12:10 pm
 km79
I filed the yellow bleed block down from 10mm to approx 9.3mm. Made a big difference to level feel/travel.
Posted : 13/03/2017 12:17 pm
Yes. But also sounds like you still have air in the system, probably at the caliper
Posted : 13/03/2017 1:19 pm
Try bleeding from the caliper up to the levers.
That way any air is going to rise with the fluid.
Posted : 13/03/2017 2:40 pm
