Mini pump recommend...
[Closed] Mini pump recommendations? - cheapish & pocket sized
[#4720232]
Need a new mini-pump, something that'll go in a jersey pocket easily & will do mtb volume or road pressures.
Last one was a Blackburn AirStick but they're not very kind on valve stems.
Any recommendations?
Ta 🙂
Posted : 06/01/2013 7:07 pm
I have a topeak pocket rocker master blaster which is good enough to put 100 psi into road wheels and small enough for a jacket pocket (though mine lives on the bottle cage mount)
Posted : 06/01/2013 7:13 pm
Topeak Race Rocket is pretty good, about pocket sized. It has an extendable hose, which helps avoid bending the valves.
Posted : 06/01/2013 7:18 pm
Cheers both, shall have a look at those.
Posted : 06/01/2013 10:11 pm
Not crank brothers if you want it to work.
Posted : 06/01/2013 10:13 pm
I use a Crank Brothers pump. Admittedly it is fiddly if you don't read the instructions, but fine once you figure out how it's supposed to work.
Need a second portable though. Ideally something with a gauge. So watching with interest for the alternatives.
Their customer service is beyond reproach though. At least, has been for me.
Posted : 06/01/2013 10:21 pm
 Del
topeak mini morph. will reputedly go to over 150psi. nice and easy to use, smallish, not that cheap, but very good.
Posted : 07/01/2013 12:05 am
Leyzne Alloy Drive. Had it since it first came out some years ago and is brilliant. Compact, light, robust and great at inflating comes in a range of colours too. Mine was about £20 3-4 years ago.
Posted : 07/01/2013 8:21 am
+1 for the Lezyne
Posted : 07/01/2013 8:25 am
Yeah until it stops working.
Posted : 07/01/2013 8:58 am
The Lezyne's with their hose attachments make life so much easier in my opinion - I wouldn't be looking at any other manufacturer.
Posted : 07/01/2013 9:40 am
Topeak race rocket is brilliant really easy to switch between both valve types, has a felixable hose and will fit in your pocket. It's also got my road tyres up to 100 psi before now.
Posted : 07/01/2013 10:02 am
I've just bought a Topeak race rocket & I'm very impressed so far.
Replaced the Blackburn that let me down in the dark & rain last week.
I don't care about a 'lifetime warranty' I want the thing to work in the first place!!
