Mildly swept bars
[Closed] Mildly swept bars
[#10129397]
I'm on the look out for some handlebars with a sweep greater than the 8-9 degrees that is fairly common. I think 12 degrees would be fine. I've come across SQLab and Syncros but I'm also looking for other options. Bonus points if they're available in 35mm as that would avoid a stem change.
Posted : 05/08/2018 10:50 am
Syntace also do 12degs. Not sure about 35mm though.
Posted : 05/08/2018 11:00 am
Ah - I meant Syntace and not Syncros 😶
Posted : 05/08/2018 11:03 am
On One Fleegle Pro on my bike. They are the only one I've found other than SQ labs.
Posted : 05/08/2018 11:25 am
Salsa do 11 deg if you can find them.
I have a set but in 31.8mm diameter.
Posted : 05/08/2018 2:36 pm
Are those Rustlers  - and would you be prepared to part with them?
Posted : 05/08/2018 2:42 pm
17 degrees is the goldilocks angle.
<span style="font-size: 0.8rem;">Swept back enough to be comfy but not too swept to feel odd.</span>
Posted : 05/08/2018 3:09 pm
They are Salt Flat 2s
750mm width.
Posted : 05/08/2018 7:03 pm
I might be interested if scotroutes doesn't want them.
Posted : 05/08/2018 9:49 pm
Fleegles are good. I think the 25.4 bar/stem helps with
comfort, too
Posted : 05/08/2018 11:30 pm
Titec Flat Trackers are only 700mm but feel good with an 11 deg sweep. £21 here -
https://www.sjscycles.co.uk/handlebars/titec-flat-tracker-handlebars-11-deg-318mm-clamp-700mm-black/
Posted : 06/08/2018 12:22 am
Stooge Moto, but they're 17 degree, 31.8mm only and are rarely in stock.
Posted : 06/08/2018 4:02 am
Thanks nairnster. I was after something with a bit of rise too.
I might be interested if scotroutes doesn’t want them
Go for it!
Thanks for all the other suggestions too. I'm not sure that 16/17 degree bars will work well on a AM full-suspension bike so still prevaracating.
Posted : 06/08/2018 11:51 am
@scotroutes no problem
@molgrips  if you are interested am sure we can sort something out.
Posted : 06/08/2018 3:01 pm
