Mid to long travel ...
[Closed] Mid to long travel 29 er list please.
[#7901833]
As you all are aware I'm looking for a hardtail 29er frame to build up.
So far I'm stuck between a ragley bigwig and a nukeproof scout 290.
Before I pull the plug are there any others I should be looking at.
Needs to take 120-140 fork and able to have a front mech.
142 through would be a bonus too.
Help me out here peeps !!
Thanks.
Steve.
Posted : 21/06/2016 7:39 pm
I'd be giving my money to Last right now if they had any large Fastforwards left.
In fact I will be giving them some money from "around June 15th"
Posted : 21/06/2016 7:46 pm
I think you'll be happy, stu. Best fun riding I've had this year was chasing a friend on hsi 160mm bike down one of our Enduro trails on the FF, right on his tail.
Posted : 21/06/2016 7:56 pm
Where can I look at these please and how much are they ?
Posted : 21/06/2016 8:01 pm
George.
I just wish I'd looked past the offset back end and ordered one first time round when I had the chance. 😳
Posted : 21/06/2016 8:05 pm
 ton
in the market for something similar myself. thinking a stanton sherpa or a cotic solaris. 130mm forks are plenty ona hardtail. owned 2 150mm forked hardtails in the past.....pretty awefull on anything other than downhill.
Posted : 21/06/2016 8:07 pm
New Production Privee GT 29er out in November, worth waiting for?
Posted : 21/06/2016 8:09 pm
What's the score with the offset rear end and wheel then ?
Posted : 21/06/2016 8:10 pm
Better spoke angles for more lateral wheel stiffness, so the drive side spokes are further from the vertical than on a normal wheel build where the rim is exactly in the middle of the dropouts.
Posted : 21/06/2016 8:42 pm
+ another
Posted : 21/06/2016 8:50 pm
@chief
I assume that means that The Last FF needs a specific rear wheel build then, or am I being thick?
Posted : 21/06/2016 8:51 pm
My guess is just a re-dish. About a tenner at your LBS.
Posted : 21/06/2016 8:58 pm
Pole Taival? I'm currently lusting over an evolink 140.
Posted : 21/06/2016 9:02 pm
As nice as the Last is I would need a complete new wheel as mine is 142.
Plus it has slidey dropouts which Im not a fan off as the ones fitted to my old Bizango kept slipping.
Is the vitus sentier 29 any good?
Posted : 21/06/2016 9:09 pm
How did you get the Bizango dropouts to slip? I hammered mine ss and they never budged.
Posted : 21/06/2016 9:22 pm
I dunno, Im a heavy bugger so I guess that could of had something to do with it
Posted : 21/06/2016 9:28 pm
Are you new here Clink? 😉
:mrgreen:
Posted : 21/06/2016 9:32 pm
Surprised you've not mentioned a 2Souls Stu? 😀
Or how about Kona Honzo - in steel, alu or ti (now carbon too).
Or Canfield Yelli, Nimble 9 or Epo?
Posted : 21/06/2016 9:36 pm
I'll just leave this here:
Posted : 21/06/2016 9:38 pm
Wasn't your last thread just a list of long travel 29ers? Now you want a list of long 29ers.
From what I gather just buy anything as you'll not like it and will want rid soon enough.
Posted : 21/06/2016 9:40 pm
Doing some research to make sure i buy correctly
I would like a frame that can take 140mm forks and have a decent reach
Posted : 21/06/2016 9:45 pm
 ton
if that is a solaris, i want a xl if anyone is selling
Posted : 21/06/2016 9:47 pm
renton - Member
Just go and try a few different bikes and work it out for yourself.
There's a list of them up there.^^^
Posted : 21/06/2016 9:49 pm
singlespeedstu - Member
George.
Yeah... would have preferred boost, but since I was buying wheels for it, it really didn't matter. Zero hassle with wheel changes thus far (and I've had a few.... still figuring out pressures)
Posted : 21/06/2016 9:55 pm
ton - Member
Yes, It's a Mk2 Large. Best hardtail I've ever ridden 🙂
Posted : 21/06/2016 9:58 pm
Singular Swift takes up to 120mm according to Sam, although it might be a bit slack and floppy.
Mine is 100mm, and it's great, but I have been wondering about turning it up a bit.
It's a great frame though.
Posted : 21/06/2016 10:16 pm
Swift bit limited by head tube too, only straight steerer forks.
Posted : 21/06/2016 10:20 pm
Nice that Solaris.
Can't find a honzo in frame only.
Worried the bigwig will be to short and to similar to the parkwood.
Concerned the nukeproof will be to stiff.
Posted : 21/06/2016 10:21 pm
 br
Try Steve D at I-Cycles, I'm pretty sure he had a large FF frame in.
Posted : 21/06/2016 10:24 pm
Geometry with commitment! Minimum 100mm travel forks or 490mm rigid. Strong enough for [b]up to 120mm[/b] forks
That'll be the Solaris ruled out then.
Personally can't see why you're insisting on up to 140mm on a 29er hard tail (me, Mk I Solaris, 100mm Reba's)
Posted : 21/06/2016 10:29 pm
I have a set of 140mm revs that I'm hoping to use.
Would it be easy to shorten the travel on them ?
Posted : 21/06/2016 10:41 pm
Can't honestly say but my Reba's are 120's shortened by 20mm.
And I've a pair of revs in 120 flavour on lend to try out as part of my 650 B+ experiment.
So I'd be surprised if it wasn't.
Posted : 21/06/2016 10:54 pm
Also, Solaris is 135mm rear end.
The new Stanton is 140mm compatible and is to have swap outs for ss, 135 and 142 iirc but best to check the website.
Posted : 21/06/2016 10:56 pm
I also have a 142 x12 rear wheel that narrows the choice down.
Basically I'm trying to build two bikes up (1 full suss and 1 hardtail) with the same bits so I can swap them around quick enough if I wanted to ride one or the other.
Scout frame can take 140mm and 142 as can the bigwig.
Are there others.
Posted : 22/06/2016 12:08 am
Are there others
Um....Canfield YS, Nimble 9 and Epo. All 142 and will take a 140 fork. Choice of alu/steel/carbon.b 😯
Posted : 22/06/2016 6:34 am
I wouldn't - someone will have it away.
Posted : 22/06/2016 9:21 am
Edit Didn't read the OP and answered for full sus frame.
Posted : 22/06/2016 9:58 am
owned 2 badly designed 150mm forked hardtails in the past.....pretty awefull on anything other than downhill.
Fixed that for you. I'd recommend a Chromag Rootdown (or BA) about now but it appears Shore Lines aren't bringing them in this year.
The Ragley looks alright, wasn't around when I got the Rootdown last year.
Looking at my spreadsheet from last year you should look at the Transition Trans-Am 29, Banshee Paradox and Titus Fireline Evo.
I might also be tempted to have a look at Nicolai for a Custom Argon-TB with Geometron-esque Geo.
Posted : 22/06/2016 9:59 am
140mm is long travel 😯
I was going to suggest The Wreckoning, but that must Extra Long Travel with 160mm. 😉 😆
Posted : 22/06/2016 10:15 am
renton - Member
Very few 142 wheels that can't be converted to QR, I'd have thought - waht kind of hub/wheel is it?
Posted : 22/06/2016 10:27 am
It's a specialized own hubbed wheel which I don't think it changeable.
Posted : 22/06/2016 10:50 am
Specialized hubs tend to have DT Swiss internals, so a set of the right DT end caps will probably do the trick.
Posted : 22/06/2016 10:58 am
As per honourablegeorge, who I might add has still not posted anything significant about his fastforward; 142 and 135 are basically the same axle length and are usually easily converted between each other.
Posted : 22/06/2016 11:30 am
