messed up my bb she...
[Closed] messed up my bb shell
[#9641746]
Cack-handed, ham-fisted, dyslexic fool that I am, I was in a rush, got confused between left and right re-installing my bb and I've messed up the threads in the bb shell of one of my bikes 😳 At least it was the oldest cheapest bike but I can't afford to replace it.
Anyone had the threads on their bb re-tapped? It seems there is a park tool tool that does this but when I phoned up my lbs they said it wasnt possible 😕
Any thoughts?
Posted : 02/11/2017 10:41 am
what's the frame and BB shell made from?
Posted : 02/11/2017 10:42 am
 P20
It depends on how screwed it is. If the shop actually see it in the metal they may decide they can do it
Posted : 02/11/2017 10:43 am
If it's only the 1st few threads you could try a Saint BB. They have longer cups/threads.
Posted : 02/11/2017 10:44 am
Rescued an aluminium frame myself with a Saint BB earlier this year.
That's the cheap fist option.
APF
Posted : 02/11/2017 10:49 am
wwaswas its a cheap alu Ridley I use as my commuter/pit bike for cx
StevieD yes only first few threads, but a road bb - if that makes a difference
Posted : 02/11/2017 10:50 am
As above Saint BBs have longer threads on the drive side.
RF X-type DH have longer threads on both sides
Posted : 02/11/2017 10:54 am
Alu's probably more tricky but a frame buildre could try and resuce the threads or sleeve it. Might cost more than a second hand replacement though.
Cheers. There is a frame builder near the LBS so might be an option if not too pricy.
I'm pretty sure is only the initial threads and only on drive side so Saint BB might do the trick if it would be road compatible? 24mm axle but i think it sounds like different width cups?
Posted : 02/11/2017 11:11 am
the idea with the saint bb is to use it as a cutting tool to restore the threads, then use the original BB as intended. I'd thread lock the eventual BB in place too, if it were me.
Posted : 02/11/2017 11:16 am
I've had a BB shell re-tapped, although that wasn't cross threaded, more of installed without any grease and left to corrode in place.
Turned out to be easy for the shop (Roll for the Soul if you're in Bristol)
Posted : 02/11/2017 11:23 am
Get a decent lbs, yours sounds useless.
Posted : 02/11/2017 11:24 am
To be fair they are pretty good normally and I was a bit surprised. However I didnt recognise the voice of the guy I spoke to so might have been new staff.
Posted : 02/11/2017 11:39 am
 Bez
If it's only a few threads crossed then it can probably be re-tapped with care. If not then helicoiling will work. And if all else fails then a threadless BB is an option. Your LBS is throwing the towel in too early 😉
Posted : 02/11/2017 11:48 am
Bez +1
Posted : 02/11/2017 12:50 pm
Working at home so had a quick look again in the light of day just now, really was only minor damage to the first couple of turns in so a bit of careful filing of the burrs/misshapen threads, a bit of cleaning and very carefull installation and I have a BB in place again 😀
The last one lasted 3 years so hopefully this one will too!
Posted : 02/11/2017 2:42 pm
 Bez
Yeah, on an aluminium frame a robust BB can often tap out minor damage itself 🙂
Smug points for you next time you're in the LBS…
Posted : 02/11/2017 6:27 pm
😆 yep!
Was pretty relieved I didn't have to fork out any cash for such a daft mistake!
Posted : 03/11/2017 8:04 am
