Magura forks remote...
[Closed] Magura forks remotes
[#1144375]
Hi, anyone know if the remote travel adjuster on Thor forks is locking or not? would a RS poplock or pushlock do the job?
Posted : 19/12/2009 5:26 pm
poploc works if you stop it locking
So, i take it they should not be of the locking flavour then? Just got some Thors but without the remote, so don't really know, although the adjuster on the fork leg does spring back once travel adjustment is done, so that would make sense. The info on the Magura site is not to good!
Posted : 19/12/2009 5:31 pm
It not locking, you hold the remote, lean on the forks to reduce the travel, then release the remote. It's not a great system. I very very rarely use it, I prefer to remove the compression damping and make the fork very active if i need it on techy climbs and such
Posted : 19/12/2009 5:56 pm
