So my son, in his infinite wisdom, managed to lose a screw from his Magura calipers when shortening the hoses/bleeding them??? Is anyone aware of any shops that have them in stock.
So far we can only find Tredz but that's the usual 5-7 days wait.
Ta.
Seems to be a few places having them in stock on ebay. Depending where you are you could potentially even collect if a seller is local to save some shipping time?
Just the bleed screw from a Caliper? Which caliper & where are you?
Good shout on eBay, found some that should arrive by Mon/Tue.
@dangeourbrain They're MT5 calipers and it is just the bleed screw. Chesterfield based.
Chesterfield based.
Ah, not that close to me then - was going to say if you're local you can have one as I've a collection of calipers in the garage...
NP. Thanks for the offer anyway 👍
Pop down to your local engineering shop, or parts supplier (not Screwfix) with the screw that you have for comparision.
Probably will be metric.
They will be able to offer something suitable.
Yeah it's a bit odd as it has about 1mm at the end where the thread doesn't exist. I assume it's this part that plugs the hole so to speak.
