Lyrik SOLO or 2step...
[Closed] Lyrik SOLO or 2step air- Any users?
 hora
[#1386632]
How do you get on with the big 'gap' between 160 and 115?
If solo air - do you ride XC'ish rides on 160?
Any niggles/gripes and how do they perform in general?
Posted : 05/03/2010 11:37 pm
Been impressed with my 2 Steps, for climbing 115mm is pretty good and then barrel up to 160mm for goin down, not sure I would use anything in between, had U-Turn on forks before abd tended to use only the upper and lower limits.
Very plush and adjustable.
Posted : 05/03/2010 11:42 pm
Solo air here, brilliant fork and much better suited to my weight than U Turn as I seemed to between spring weights. I have spacered mine down to 145mm. Lyriks feel kind of strange at 160mm imo, wouldn't want to ride XC at that anyway.
Posted : 05/03/2010 11:52 pm
I've got Solo Air Lyriks on my Nomad and I ride everything on them. XC, DH and stuff in between. I like them
Posted : 06/03/2010 12:07 am
2-step here....
top fork other than when the 2-step stopped stepping and would stay at 160.
all fixed now, though. top fork. run it on a DB Alpine. flick the switch and with a little jab on the forks it drops to 115. no need to use the lock-out as it firms up when at 115, but with enough 'give' for hefty hits.
run it fairly soft and it sits at ~140 with sag.
really ahppy with it.
Posted : 06/03/2010 12:08 am
 hora
Perfect.
Thanks guys. Agree on the Uturn comment.
Posted : 06/03/2010 8:39 am
I have a set of 2 step forks on my Remedy. Really good to be able to drop it for steep climbs. Makes it easier to keep the front wheel on the ground.
Posted : 06/03/2010 8:43 am
 hora
What pressures are you using (2step) and is there a routine - put pos in first before neg etc?
Posted : 06/03/2010 8:50 am
don't think mine has pos and neg pressure?
I followed the setting instuctions from treks website for my weight, and made a few tweeks after the 1st few rides. really good forks, far better than the talas I had before.
[url= http://www.trekbikes.com/pdf/owners_manuals/Suspension_Setup_2009.pdf ]trek set up guide[/url]
Posted : 06/03/2010 8:58 am
 hora
Wow perfect. Thank you Muggo
Posted : 06/03/2010 9:21 am
i have solo airs. They're hard work for usual XC jobs, so i only save them for the silly xc rides (or DH). I've heard lots of problems about 2-steps (opens a can of worms)...
Posted : 06/03/2010 9:26 am
don't thank me, thank those great guys at trek bikes.
certainly does make it easier as there is a lot of things to tinker with.
enjoy those forks.
Posted : 06/03/2010 9:27 am
 hora
Hansrey- post 09 though(?)
Posted : 06/03/2010 9:44 am
yup post '09.
if you pick up a set of earlier Lyriks send them off to Fisher if/when they go wrong and you'll have a top set of forks....
Posted : 06/03/2010 10:24 am
 hora
Bought them. Crikey they look nice.
£450 brand new 2009 set from LBS 😀
Posted : 06/03/2010 6:52 pm
