Does anyone other than Marzocchi do low pressure ~100 psi forsk/shock pumps? I have borrowed a friends, but it leaks enough air out when removing the hose that I'm not in a hurry to drop 30 notes on one.
Any recommendations?
I've never heard of any other low pressure pumps except the Marzocchi one, although Truflo do a dual pressure one where you change the pressure guages.
In my experience they all leak air when removing them, but this is only air from the hose under pressure and not from the shock. When you connect them some pressure from the shock also fills the hose - hence an apparant loss in pressure.
Ah, thanks for the help! I may continue to borrow my mate's one until one comes up on the classifieds 😀
