Loose Spokes
[Closed] Loose Spokes
[#6573429]
I keep getting spokes coming loose on my rear wheel. Not a little bit loose either, like 10mm movement either way loose and it's happen a few times. I nip it up and another one will come loose. The wheel is out of true a bit as well.
I assume this is because tension isn't right across the wheel? If this is the case, can someone suggest where to get it looked at in Leicester, wheels are one thing I really don’t have a clue how to sort.
If it makes any difference, they’re hand built Arch EX rims on Pro 2 hubs (no idea what the spokes are), that are about 2 ½ years old.
Posted : 22/10/2014 12:08 pm
If you don't know how to true a wheel than randomly tightening loose spokes won't do much good.
I don't know your area but any de bet bike shop should be able to true and retension the wheel for you.
Either that or learn to do it yourself. If you're a the practical sort and good with your hands you'll pick it up quite quickly. 🙂
(If you're not, then you won't!)
Posted : 22/10/2014 12:21 pm
Take to an lbs they'll only charge you peanuts to tighten & true them properly ?..
Btw,how heavy are you & where dya ride ?..
Posted : 22/10/2014 1:08 pm
LBS would be great but to be honest I don't really have much faith in any of them.
PeterPoddy - Member
Granted, but when you realise half way through a big ride that you have a flappy spoke!
reedspeed - Member
About 85kg kitted up I think, thend to ride either Cannock or the Peak District.
Posted : 22/10/2014 1:18 pm
There's something clearly wrong then,as you're not that heavy or hammering em are ya ?.. You may need to get them re-built with new spokes etc.
I'm 25kgs heavier than you and have the same wheels on a 650 crush hardtail and some Hope enduros on a 5,& I'm
All over the place & I don't have any problems .. Crests are a weaker rim,I've had them before ,but I'd be going to a specialist to seek advice ,perhaps someone on here can direct you !.
If you have another bike or can do without it for a week just post em some where !..
And another thing I'd fo is ring Hope direct there customer service is the best !..
Hope 01282 851200
Posted : 22/10/2014 1:31 pm
They take a bit of a hammering in the Peak and on trips to distant places over boarders but no not overly!
Just spoke to someone local who's going to have a look for me, hopefully they won't need a rebuild.
Not much use speaking to Hope, they where hand built before you could get Hoops with Arch EX rims.
Posted : 22/10/2014 1:49 pm
