Longer spring assem...
[Closed] Longer spring assembly for Reba Solo Airs?
[#6858707]
Hi,
Got a reba rl 100ml solo air, would like to get it to 120mm, believe I need a longer air spring assembly, as it's not like the good ol' days of having to remove a spacer or two 🙁
Anywho, anyone know if they're available and if so, where? As I can't seem to find one.
Many thanks,
Naff.
Posted : 13/02/2015 11:44 am
I would download the manual and check inside the fork to see how your air spring is constructed.
Someone posted a Sektor solo air manual a few backs that stated you could change travel by adding / removing spacers.
I was incorrectly advised by SRAM tech that all Rock Shox solo air springs do not use spacers to change the travel and a new air spring was required. But the Sektor manual contradicts this.
Also if new spring is needed then contact your local shop or suspension tuner who should be able to order it for you.
Posted : 13/02/2015 12:44 pm
