Longer front skewer...
[Closed] Longer front skewer - is there such a thing?
[#7241714]
I'm looking for a long front QR skewer. I'm attempting to fit limpet panniers to my road bike but with the width of the extra metal in the drop outs there isn't enough thread left to screw the nut on to the skewer. Any ideas?
Posted : 03/08/2015 12:21 pm
How much longer? Rear QR skewers are an inch longer.
Posted : 03/08/2015 12:22 pm
Cut down and re-thread a rear?
Posted : 03/08/2015 12:23 pm
10-15mm longer would be about right. I dont have a die cutter so was hoping that I could avoid purchasing one.
Posted : 03/08/2015 12:25 pm
http://www.chainreactioncycles.com/halo-porkies-skewer-set/rp-prod26623
I have some here and the packet says maxium dropout capacity 8.5mm
Problem solved. Getting threads cut onto a skewer.
Posted : 03/08/2015 12:32 pm
be careful how much you tighten it.
Cut threads are not the same as rolled threads 🙂
Posted : 03/08/2015 12:33 pm
Halo Hex come in standard and XL length, but it doesn't state the XL length http://www.halowheels.com/products/part/HUHAQHXD
Posted : 03/08/2015 12:38 pm
They are perfectly adequate if the original OD is correct.
Posted : 03/08/2015 12:40 pm
Forgive me I wasn't aware I said they were inadequate only that you'd be wise to not overtighten resulting in a broken skewer and no more riding.
And its the narrow diameter that matters when it comes to the strength of a thread 😉
Posted : 03/08/2015 12:49 pm
I have HALO hex on the front of my Kona PhD. With Project 2 forks I have about 12mm of thread over what's required.
Posted : 03/08/2015 1:53 pm
