philxx1975 - Member
They would not discuss warranty of grey imports which this is OEM stock retail stock comes in retail boxes.
Grey imports they consider it's come from outside of the home market. Within the EU, so long as it's sourced from an EU country, the law says it's the same as being bought in the same country and there's no such thing as a grey import. If it's been sourced from outside the UK but within the EU and they kick up a fuss, challenge them as they're breaking EU law. Still though your first port of call is with the original retailer really for any warranty as your contract is with them.
OEM is tricky however as technically OEM stock shouldn't be being sold as retail. They are to be supplied to manufacturers as a component to build with. CRC and the like get hold of the stock cheap and flog to end users.
Not sure on the law there, but still once it's been sold to you I think EU warranty laws should still apply just the same.
Many try to wash their hands of responsibility, mostly because they object you've gone through channels that are out of their control so they haven't been able to artificially fix a high price.
I don't see a problem.
If it goes wrong your contract is with the LBS.
I'd just go for a ride if I were you.
It's the [i]principle[/i] apparently..
Not getting it myself tbh..
Not sure how this affects Shimano?
Nothing directly, but as CRC and Hotlines IIRC are the same business some LBS will have accounts with them. IF madison are out of stock or high on pricing for the product then they will go through other distribution channels.IN this case CRC to get YOU what YOU wanted,
At the end of the day you walked into a shop and got what you asked for.
How many warranty items have you sent back to Madison directly? None you say? So it's a theoretical issue, as the issue is exactly the same, you return it to your LBS.
