Kona Process Pivot ...
[Closed] Kona Process Pivot Bolt
[#8031987]
Ladies and gents...
Does anyone know what this washer does on the main pivot bearing?
[url= https://goo.gl/photos/nfESAE32nWq7PEb97 ]click for image[/url]
When I screw the pivot bolt in it doesn't tighten against anything and the washer just drops out...I'v had to resort to positioning the bolt where I want it and waiting for the loctite to set, and then putting the washer in my toolbox after I pick it up off the floor
Posted : 02/09/2016 5:26 pm
Is it tapered either side?
Posted : 04/09/2016 4:16 pm
the washer is not tapered, neither is the pivot bolt or the bearing inner races. masses of loctite is currently doing the trick!
Posted : 08/09/2016 12:31 pm
I don't have a washer, i did that one on my 153 2014 frame the other day... no washer
Posted : 08/09/2016 12:37 pm
