Kona Process - inte...
[Closed] Kona Process - internal cables
[#7510434]
Hi all,
Got a 2015 Kona Process 153DL, with a KS Lev seat post.
Want to replace the rear mech inner cable and the seatpost inner cable, both of which are internally routed.
Before I yank them out, does anyone know how they are routed inside the frame? Is there a guide for the inners inside the frame, or am I going to have to try to line up the inner to the outer where it leaves the frame?
Ta,
Duane.
Posted : 11/12/2015 12:49 pm
The mech cable has nice internal routing, its a doddle, the downtube bit on mine was full of crud a good blast of gt85 cleared out loads of dirt and did wonders for the shifting
I'd assume the dropper is the same?
Posted : 11/12/2015 1:51 pm
Built up a 111 from bare frame the other week, no problem once I'd worked out where all the holes were.
Posted : 11/12/2015 1:52 pm
Great thanks, so shouldn't have any issues with pulling both inners out, blasting with gt85, and replacing cables.
Ta,
Duane.
Posted : 11/12/2015 2:21 pm
