Knocking noise when...
[Closed] Knocking noise when compressing shock after fitting RAD cage to rear mech
[#7959045]
Fitted the mech spring through the correct RAD cage hole. Noise only happens with clutch engaged, so backed off clutch tension, which makes less noise but it's still there and I would prefer full tension on the clutch. Any ideas why, will it free up with use?
Posted : 22/07/2016 3:37 pm
