Kenda Small Block E...
[Closed] Kenda Small Block Eights - Stan's Flow - Any comments?
[#833062]
I want to run these tubeless. I'll probably go for 2.35". Are only folding ones available?
Posted : 02/09/2009 12:58 pm
 Dan
thin sidewalls, which might or might not be an issue depending on how, what and where you ride.
Posted : 02/09/2009 1:03 pm
Hmm... Thinking of Moab. Might not be good.
Posted : 02/09/2009 1:05 pm
I have the tubeless versions, they have a thicker sidewall, but then they do weigh in at nearly 800g per tyre! Not the best tyre purchase I have ever made, has done nothing but rain since I fitted them.
Posted : 02/09/2009 1:11 pm
can you use sealant with kenda tubeless tires? i heard no...
Posted : 02/09/2009 1:24 pm
Ive got a 2.1 and a 2.35 folding, both converted with Stans (ghetto). Both loose air slowly - although the 2.1 does so quicker. Still only takes a couple of psi per week. Both very easy to mount and seal initially.
I dont know why but the 2.35 doesnt feel as grippy as the 2.1 (on dt 4.2d rims)- I bought the bigger one to put on the front but now run it on the back.
Posted : 02/09/2009 1:42 pm
how tdo these size up compared to maxxis high rollers?
got a jumpy frame wich needs a small back tyre and i thought these look the ticket
Posted : 02/09/2009 2:04 pm
Kenda tyres are big. I think a 2.35" SB8 is about the same as a 2.5" High Roller.
Posted : 02/09/2009 2:11 pm
2.1 Nevs look like 2.35 High Rollers...
Posted : 02/09/2009 2:23 pm
