I’m trying to find a headset for the above mentioned KM. I’ve tried looking at the compatibility charts and literature and it’s like giving a dog a copy of Stephen Hawkings Brief History of Time. I still have no clue what it is I need. If someone could please <span style="font-size: 0.8rem;">point me in the direction of the actual parts I need (a link would be amazing) as I’m close to throwing my iPad out of the window.
thanks in advance Jim</span>
I was just browsing these frames form the other thread - Recommended headset: ZS44/28.6 | EC44/30
Type 2 here for the top:
https://www.chainreactioncycles.com/ie/en/hope-pick-n-mix-headsets-top-cup-/rp-prod70725
Type H here for the bottom
https://www.chainreactioncycles.com/ie/en/hope-pick-n-mix-headsets-bottom-cup/rp-prod70727
Other brands available, obviously, but ZS44 top (zero stack 44mm) and EC 44 (External cup 44mm) bottom are what you're after.
Also noticed this, which i found surprising:
"Please note that the manufacturer recommends to treat the inside of the frame tubes with corrosion protection before installation despite the ED coating."
Thank you
Type H is ec44/40 is that correct?
Yeah, CRC list it as "EC44/40 - Type H"
This is really helpful in understanding - you'll see what your headtube looks like in the diagram, second one labelled "integral".
Sorted....parts ordered. Cheers!
