just to check: deor...
[Closed] just to check: deore external bb ok with m960 xtr cranks
[#1080066]
Im prettttty sure its fine but just to double check
Posted : 27/11/2009 4:33 pm
yep should be all good!!
as far as im aware all HTII bb fit all HTII cranks??
Posted : 27/11/2009 4:41 pm
yeah i think saint might be dif and m970s are def different
Posted : 27/11/2009 4:44 pm
Does Deore weigh the same as XTR?
Posted : 27/11/2009 4:48 pm
I've got a xt ht 2 (the first generation...whatever number that is) which I recently fitted saint cups to, all runs fine so far.
Posted : 27/11/2009 5:25 pm
 dobo
i'm running a deore BB on some xt cranks, tbh i'm not sure what the difference is with the xt bb and the deore.. certainly weight wise i cant tell in the hand, never weighed them though, when it dies i will rip it apart to expose all to find out if the bearings and seals are the same as xt.
Posted : 27/11/2009 8:01 pm
fontmoss - Member
M970 can be used with Deore through to XTR. Saint are the same except the M815 model which uses a longer centre tube but the cups are the same.
Posted : 27/11/2009 9:13 pm
ah ok so its just the shape on the circumference of the cup on the m970 bb that are dif?
Posted : 27/11/2009 9:19 pm
