Hi all , anyone know where I can get my Joplin serviced ?
Ian
www.2pure.co.uk
How much of a service does it need? Lower lube is a doddle just unscrew top collar and 10mm bolt. Adding air (and oil) also pretty simple, some good info and threads on mtbr. 2pure got a backlog waiting for parts so if you need seals etc you're looking at 4 weeks-ish turnaround.
Thanks I'll try the lube and air first and see how it goes.
http://forums.mtbr.com/maverick/speedball-tech-tips-november-2007-a-354520.html
Blow by blow instructions. Not as difficult as it sounds and a few similar threads in there. I've been doing oil air top ups for a few months nursing a joplin and it takes less than 10 minutes. Lower lube is a 1 minute job.
[i]2pure got a backlog waiting for parts so if you need seals etc you're looking at 4 weeks-ish turnaround.[/i]
Sent mine in end of last month...guess it's going to be a while just like when it went in last year at the time when Ran left 😐
Anyone know if it's still Steve doing the repairs or has that changed?
No idea, munqe chick spoke to a Jake. Just sent hers back under warranty but didn't want to lose it over big holiday last month hence learning to do some stuff myself. Think they are waiting on seals etc from the US so out of their hands.
He left recently which has caused some delays.
hi guys , i followed the mtbr guide to the letter but the seatpost now won't move, it's locked in full extension,any idea's please ?
ian
nobody could replace ran - he's too dreamy
Invert it and work the lever a couple of times, you need to release the valve to get the air and oil in the right place. Re check air pressure.
I followed the air pressure guide when doing mine (and oil levels) and found them to be a bit OTT. Reduced them a bit and its given me over a year of trouble free use. Need to replace the guide block now (which I did wait a while for the come from the states but 2Pure told me about that and it was still usable until it arrived. Plus I ain't going to grumble as it was gratis).
Davey, how much oil and air did you put in ?
