Islabike - wrap/pro...
[Closed] Islabike - wrap/protection
[#12111854]
We've just got an Islabike Cnoc 14 in great condition from a friend. I'd like to wrap or tape it to keep it in good condition for both kids and eventual resale. My son will be using it first. It's purple/pink which I don't think he will be bothered by at all, neither am I. But in thinking about taping it, I realised there could be the possibility of using some coloured tape or wrap to make it look different. This could then be removed and re-done to make it look like a 'new' bike for my daughter when the time comes.
Maybe I could clear wrap or tape the tubes then use some sort of coloured tape on top. I've used heli tape before but not vinyl wrap. I wouldn't be going for a complete and seamless wrap. I think black wrap with the tube joints left purple would look great
Any ideas?
Posted : 14/11/2021 2:39 pm
Lots of option nowadays, depend on how much you wanna spend.. Invisframe being the obvious and most expensive (admittedly I don't know if they do Islabike kits), local shop is selling a product called Dyedbro a universal frame protection to fit most bikes, with many awesome designs to choose from. I've not tried it but it sounds like a option for you if you want to change the frames look
Posted : 14/11/2021 3:17 pm
I came across the Dyedbro ones recently. I think all the designs are on a transparent backing though. Ideally I don't want to spend too much.
I wonder if I could clear tape the bike then put something on top of that. It doesn't have to last forever.
Posted : 15/11/2021 12:16 pm
Paint on Islas is tough.
Ours has had many owners and still looks fine after plenty use with a quick t cut for the next owner.
Posted : 15/11/2021 12:50 pm
@trail_rat up until the latest models the paint has been gloss. It's now slightly matt, not sure if it will T-Cut up the same now. I use Autoglym Super Resin Polish on bike frames and it works a treat
Also, I'm hoping to stop paint being bashed off, not just scuffed.
Posted : 15/11/2021 1:16 pm
 pdw
Heli tape the cable rub points and it'll be looking well above average come resale time.
Also worth a look at photos of 2nd hand ones on ebay/Facebook to figure out the common bash points.
The tricky one is the fronts of the brake levers, but you'd be hard pressed to find a 2nd hand one that hasn't been scuffed there.
Posted : 15/11/2021 1:26 pm
Exactly what I have been doing 🙂 Seems like top tube, forks and chain stays, plus cable rub points
The tricky one is the fronts of the brake levers, but you’d be hard pressed to find a 2nd hand one that hasn’t been scuffed there.
Yeah, I think people accept all second hand Islabikes will have that
Posted : 15/11/2021 1:38 pm
I went past a rack of fancy duck tape in homebase the other day.
https://www.duckbrand.com/products/duck-tape/prints/leopard-188-in-x-10-yd
Cheap and easy enough to change regularly?
My son is on a second hand Isla bike. It was covered with scratches and heli tape.
He absolutely loves it!
Posted : 15/11/2021 2:46 pm
@tall_martin
That's the sort of thing I was thinking of. The only issue is duck tape leaves so much residue
Posted : 15/11/2021 10:10 pm
WD40 works well on tape residue.. let it soaks in and then wipe clean
Posted : 16/11/2021 3:39 pm
@dmorts
Why take it off? Just stick another layer on top 🙂
Posted : 16/11/2021 5:01 pm
I use helitape on all our bikes. It stood up to all sorts of abuse on both Islabikes and certainly helped with resale value. Remember to protect the cable runs.
Posted : 16/11/2021 5:09 pm
I'm slightly sad that kids bikes need helitaping. Kids bikes should be scratched-to-**** from all the bad parking. Helitape not much use when you reverse your car over one abandoned on the drive.
Posted : 16/11/2021 5:43 pm
