ISCG-05 Blanking pl...
[Closed] ISCG-05 Blanking plate
[#6262906]
Does anyone know of a blanking plate for ISCG-05, I'm not planning on using a chain device on my frame but don't fancy leaving the holes exposed to collect crud.
Posted : 11/06/2014 1:45 pm
If you're actually serious, why not just tape them up, or put a screw in them, or use silicone sealant.
Posted : 11/06/2014 1:48 pm
I am being serious, 😳 , was after something that would cover the exposed alu, and keep everything looking 'neat'
Posted : 11/06/2014 1:52 pm
Erm, like a crank?
Just put bolts in them and you cant see it
Posted : 11/06/2014 1:53 pm
You could weld the holes up and then get the frame powder coated so the bare metal is covered.
Or you could just leave it alone?
Posted : 11/06/2014 2:37 pm
Put some bolts in them and that way you can use them again in the future if need be. You could even get colour coded bolts.
Posted : 11/06/2014 2:47 pm
[url= http://www.ebay.co.uk/itm/like/231105611797 ]here you go[/url]
M6x5, Black, Nylon grub screws should be the lightest, cheapest way to [S]proove you are a tart[/S] bung up those holes...
Posted : 11/06/2014 2:55 pm
On my bronson I bought one of these and then took off the bash guard and cut off the tabs that held that on.
http://www.chainreactioncycles.com/mrp-xcg-triple-chain-device/rp-prod31508
As when the chain did come off it got wedged down in the ISCG-05 tabs-which was a right pain ..
Now my chain never drops off onto bbshell area
Posted : 11/06/2014 2:59 pm
