IS to PM front call...
[Closed] IS to PM front calliper confusion - help needed
 PJay
[#10548274]
The ongoing saga of fitting my Singular Swift forks (to my Swift) continues ...
The Swift for has an IS mount and I've orders an IS to PM adapter for a 180mm rotor (as fitted) the caliper (SLX) is coming straight of my PM carbon forks that the Swifts are replacing.
The adapter is fitted but now I find that the caliper bolts used to fit the caliper to the PM forks are now way too long.
Have I got the wrong adapter? The adapter is a Shimano SM-MA and marked F (Front), 180mm & P/S.
Help appreciated please so I can have a ride!
Posted : 23/03/2019 3:10 pm
If I'm following you right it's just the post mount (ie bolts going through caliper and into adaptor) bolts that are too long? If so- that happens, don't worry about it, some adaptors are very thick, some have open holes, the formula ones I like need really short bolts compared to most others. Just find some shorter M6 bolts
(there was a thread on Bikeradar where someone managed to wreck theirbrand new forks by using an over-long PM bolt and pushing the bolt right through the fork lower)
Posted : 23/03/2019 3:15 pm
 PJay
Thanks I might try that.
I bought this adapter - Shimano Mount Adaptor Front Post to IS Item Number sku54049 - from Chain Reaction and assumed that it mean Post Mount calliper to IS mount (not IS calliper to PM fork); I hope I've got the right one!
Posted : 23/03/2019 3:20 pm
I'm not seeing your SKU but Front Post To IS should be Post caliper to IS fork.
Yours I expect should be the middle of the three?
https://www.chainreactioncycles.com/shimano-mount-adaptor-front-post-to-is/rp-prod13743
There are some weird "nearly the same" fork options like old boxxers, but assuming it's a standard IS that ought to be the right one for 180mm.
Shimano ones usually come with the bolts
Posted : 23/03/2019 4:03 pm
 PJay
Thanks for that Northwind, if I add the 180mm one to the basket it shows sku54049, which is the one I bought. It came with 2 bolts which I've used to attach the adapter to the IS mount.
I've found some old M6 bolts that'll do the trick so hopefully it'll work out.
Posted : 23/03/2019 4:15 pm
 PJay
That seems to have worked. Despite finding a bolt about 1/3 of the length of the original top bolt, I've still got about 5mm protruding for the top bolt, but it was the shortest I could find that engaged all the threads (the next shortest didn't). It looks a bit 'workman like' but does the job for now.
The new Shimano adapter looks very different from an old Shimano adapter I have (from 12-15 years ago) that's also IS to PM calliper/180mm rotor.
Posted : 23/03/2019 5:39 pm
