...any good? Thanks in advance.
From summit of Ten Head to Gaudy House...
Paul
Linky not working
it is quite good.
starts off with a contouring track, then turns into a very fast grassy swoopy downhill, and the last bit is quite rough, if i remember well.
Thanks Ton.
Hopefully this link works...I was wondering about the nearby alternatives as well.
[url= http://www.streetmap.co.uk/map.srf?x=385330&y=488375&z=120&sv=385330,488375&st=4&ar=y&mapp=map.srf&searchp=ids.srf&dn=775&ax=385330&ay=488375&lm=0 ]Map linky[/url]
Cheers...
the one to the left of ten end, is a rocky rutted peach of a track too. especially the section at the side of the woods.
All BWs into Hawes and around are pretty cool and you can link them together for quite a few routes that are all interesting and quite compact around a single area! Or head south over the tops for a biggy. Also, go a bit further north to Gunnerside.
Ace, thank you. Will be taking PBW from Settle then drop into Hawes and Lady Annes Highway to Kirby Stephen.
Train back to start...cheers.
