Is there a lightwei...
[Closed] Is there a lightweight backpacking tent like this???
[#5199089]
1 person.
Single skin.
Decent sized porch for cooking/storage.
Bathtub groundsheet connected to walls of the tent by midge netting all the way around.
If not - why not?
Posted : 29/05/2013 6:12 pm
Various Big Agnes designs? e.g.: [url= https://www.bigagnes.com/Products/Detail/Tent/FlyCreek1Platinum ]https://www.bigagnes.com/Products/Detail/Tent/FlyCreek1Platinum[/url]
Sorry, you want singleskin? Have a look at Nemo maybe.
Posted : 29/05/2013 6:17 pm
That has a full mesh inner tent. I just want a trip of mesh around the top of the groundsheet connecting to the tent walls. These would have to flare outwards above the mesh strip to provide weather-proofing.
Posted : 29/05/2013 6:19 pm
 MSP
Probably difficult to get the tension right on a single skin tent with a meshing strip. I can certainly see durability problems with such a design.
Posted : 29/05/2013 6:21 pm
Lunar Solo
Posted : 29/05/2013 6:22 pm
Have Mountain Laurel Designs got anything like what you want? If not, they do custom work too. There are a few other small American brands like this, I'm struggling to remember their names though.
EDIT: [s]It seems to me that you might be as well using a mesh inner along with a tarp. Then you would have the option of using them separately in the right conditions[/s]. Ignore that...using the a mesh inner with its proper outer would be better than that, as it would be easier to set up.
Posted : 29/05/2013 6:24 pm
MHW, I think, used to do something like that but without a decent porch. It didn't work as well as you might hope and the weight savings weren't so amazing that it was worth the discomfort.
Posted : 29/05/2013 6:28 pm
[quote=flatfish ]Lunar Solo
That looks like the sort of thing I was thinking of. 😆
Posted : 29/05/2013 6:32 pm
[quote=d45yth ]
EDIT: It seems to me that you might be as well using a mesh inner along with a tarp. Then you would have the option of using them separately in the right conditions.
Possibly. I was just remembering that Hamish Brown came up with a similar design (quite) a few years back but without the mesh. It seemed to me that modern materials could make it a decent option.
Posted : 29/05/2013 6:33 pm
The Mountain Hardwear tent I was thinking of was called the Waypoint. It had a mesh strip above a bathtub-type ground-sheet to improve ventilation, but from memory, it didn't actually work very well at all. It didn't have a vestibule at all either, but the bottom line, from memory was that condensation was still a real probem despite the mesh. I suspect there aren't many similar designs partly for that reason.
Posted : 29/05/2013 6:36 pm
http://www.sixmoondesigns.com/tents.html
Sorted.
Aye. Lunar Solo currently not available. More "research" needed.....
Posted : 29/05/2013 6:38 pm
Tarp tent contrail almost fits the bill. Porch is a beak, needs a pole/stick to pitch
Posted : 29/05/2013 6:41 pm
In which case, I think brooks range do one....
Looking at your blog it's clear that your already familiar with Tarptent. Have a look at their range?
Posted : 29/05/2013 6:51 pm
lunar solo on ebay for £22 at the mo...type in 'tent one man'
Posted : 29/05/2013 7:48 pm
Go-lite do the shangri-la tarp, which you can add a floor to. I have the go-lite den2, brilliant bit of kit.
Posted : 29/05/2013 7:49 pm
[quote=matther01 ]lunar solo on ebay for £22 at the mo...type in 'tent one man'
Not when I look
Posted : 29/05/2013 8:10 pm
Yes, but the Go-lite netting lets midges in, and a Shangri-la with floor really allows the bugs in. Good tent mind.
Posted : 29/05/2013 8:24 pm
