If your star fangle...
[Closed] If your star fangled nut is on the piss...
[#4999004]
...Will this cause the headset to bind at certain places?
First of all. Yes the headsets installed in the correct order.
I've got a second hand cane creek S3 that was perfect on my old bike. Just fitted it to a sanderson life (who face their head tubes according to the website). I fitted a new star nut to some new forks, and it didn't go in perfectly straight.
Anyway, when I tighten the nut to the point where there's no play, the headset is binding and there's a rough noise coming from it.
Posted : 25/03/2013 8:29 pm
 nonk
no its not the nut to blame for that.
Posted : 25/03/2013 8:31 pm
The only other thing I can think of is the crown race... gonna try and make sure it's fully home... otherwise it's LBS tomorrow for one reason or another
Posted : 25/03/2013 8:34 pm
I don't think it'll matter, [s]its more likely you've assembled the headset in the wrong order[/s]? But you say you haven't 🙂 Have you moved the bearing race from the old fork steerer to the new?
However, I'd get a flat blad screwdriver and use it to knock the high side of the star nut down a bit.
Yep new crown race is on the new steerer. The crown race won't seat completely flush on the steerer, if I tap it with a screwdriver on the high side the other side lifts off. Suggesting it may be bent. Can't see how that's happened but this might be why.
Posted : 25/03/2013 8:59 pm
Crown race should be solid with no movement on the steerer. I've got a handy bit of scaffold tube with the right inside diameter I use for fitting mine, they need a good knock downwards to get them seated all the way round, you definitely don't want it loose at all! That might be a good place to start?
Posted : 25/03/2013 9:24 pm
its not loose, it just won't go down evenly, might be bent?...
Posted : 25/03/2013 9:57 pm
If your star nut needs straightening, put a bolt in it, and hit that to straighten it.
Posted : 25/03/2013 10:40 pm
