He only had 130mm of travel so it was unrideable (no puncture).
[b]GW[/b]
Yes. And? Hardtails are great aren't they? I'd never be without one, but I'm past battering myself senseless launching massive drops/jumps on a hardtail, or long day rides in the Peaks etc. My back doesn't take too kindly to it any more. 90% of my riding locally, and XC rides are on my XC hardtail, but the Blur is just a "fun" bike.Cool! Just like a 100mm hardtail then?
I ride bikes for fun, perhaps your motives are different 😆
Go to a DH race where there's a hardtail category and then say that trail's unrideable 😆He only had 130mm of travel so it was unrideable (no puncture).
I thought Hora was a nit of a fatty. Looks pretty normal in that pic. 😈
That trail looks mental though - 10" min travel and full body armour required....
Scienceofficer that was just after I returned to biking after an accident so my shoulder/arm/rib had recently healed. I could have kicked richc's ass with one hand tied behind my back then and now though as he's a wee bit of a soft lad 😆
My sarcasm didn't come across well then 🙁
I think I have a picture of my 2 year old nephew riding that, on his scoot somewhere, as its that core.
[i]That is Hora BTW, and that trail needs a 10" travel bike or else it would be LETHAL!!!!! [/i]
You forgot about the angleset aswell.
Shrugs. It was my comeback ride after I spent a stayover/night in Guildford hospital with a clean break on my upper arm, fractured shoulder and ribs. I guess when someones down there will always be those that'll kick you huh.as its that core.
Cane Creek, Saars and Works Components better stop making them then if you feel the manufacturer is always right 😉
Back ontopic. Is the Blur4x great? Its bloody good. At that price you could run it and sell it for a similar amount as well as it has a good following (for good reason).
Is it better than a Specialized Enduro frame? Its more boutique, better cache etc etc. It'd also feel more special to own etc. Normally I'd be tempted to buy it myself but I think I'll keep my newly bought Enduro- it seems to pedal better, ok has abit more travel but then again its about the same weight and is just as strong.
@footflaps, I have a Blur Classic that I'd like to breathe new life into, what shock do you run?
& would putting 140mm forks on, but leaving the original shock, mess it up? (am no expert on FS geometry)
I've run Reba's @ 120mm, Pike U-Turns (95 - 140mm) an Lyriks @ 160mm on my 4X.
Feels great whatever is on it, although it's in bits just now as my Blur LTc is taking precedence these days.
Always wanted one, but in the end decided that the seat tube on the large was too small.
When they eventually bring out the Blur LTc in alloy, I will get one.
When they eventually bring out the Blur LT[s][b]c[/b][/s] in alloy
There you go 😉
It was ahead of its time, but there are quite a few low and slack shorter-travel bikes around now. If they're going cheap enough though why not?
I have one and its a fun bike for razzing about on.
Too small for long days, quite heavy. Bearing and shock eyelet bush wear is tiresome and the axles need replaced yearly.
mattjg - Member@footflaps, I have a Blur Classic that I'd like to breathe new life into, what shock do you run?
The original shock was a Float R 200 with 50 stroke and I upgraded to an RP23 with 57mm stroke, so get at extra 14% travel. I really wanted a manual lockout as it bobbed like 'ell when climbing out the saddle.
The Talas 140 fork made a huge difference - mainly by slacking the head angle off by a couple of degrees (as well as more travel).
The other mod was to drill out the cable guides so I can run a full length outer for the rear mech.
I've also filed out the inside of one of the chain stays to take 2.5" tyres - only a couple of mm...
Tell me about it!stuartlangwilson - Member
I have one and its a fun bike for razzing about on.Too small for long days, quite heavy. Bearing and shock eyelet bush wear is tiresome and the axles need replaced yearly.
It did, hence my wink 😉richc - Member
I noticed this. The later ones were supposed to be 'lifetime' as well 😐
On the axle- you mean the linkage? You can buy ti linkage's now for them 8)
Yep - the big issue with the original is the bearings wearing out after about 5 rides in the rain - I mainly use mine abroad in the Alps or Colorado - nice dry trails 🙂
hora - MemberThe later ones were supposed to be 'lifetime' as well
They're lifetime warrantied - when they wear out, you send them back and get free replacements.
