ICE lift v8 cable r...
[Closed] ICE lift v8 cable replacement!!!!
[#5164648]
Has anyone got any suggestions on a way to get a cable through the right angle thingy?
I managed it in the end, but almost had rage-induced convulsions doing it. Getting the cable through such a tight bend without fraying it is very tricky and very annoying.
Can you solder the end of the cable for example?
Posted : 16/05/2013 10:24 pm
Someone on here did a guide to it. Pre bending the wire seemed to be the trick I think.
Posted : 16/05/2013 10:28 pm
Even with pre-bending it took nearly an hour!
Posted : 16/05/2013 10:29 pm
try dipping the end of the cable in superglue...
Posted : 17/05/2013 9:16 am
Errrm, it's not the easiest job in the world I'm afraid. The best way to do it is to drift out the silver pin that holds the roller (the bit you are struggling to get the cable around). It comes out star end first. Put the cable through and push it from both ends so it bends then reinsert the pin and tap home.
Simples! Well actually not simple but the easiest way.
Cheers.
Posted : 17/05/2013 10:57 am
