I Spec ii onto I Sp...
[Closed] I Spec ii onto I Spec EV,, I'm being an idiot
[#11486187]
The Internet days this can be done. I know I'm not as clever as The Internet, but...
I've got m6100 levers, and have just bought a Bonty Line Elite dropper lever.
How the hell am I supposed to put them together? The curved adapter can't fit inside the lever clamp, and if I use the Shimano nut it's 2 female threaded fittings. Is this just not doable? Or does it only work with Shimano shifters?
Posted : 18/11/2020 4:30 pm
Can’t be done as far as I’m aware.
Two different standards unless someone makes a “problem solver” adapter.
Posted : 18/11/2020 5:25 pm
https://problemsolversbike.com/mismatch
May work?
Posted : 18/11/2020 5:33 pm
Ballbags. Cheers for the problemsolvers link but not quite sure it's what I'm after.
I'll for this on the other bike with the matchmaker compatibility then, horrible Trans X lever on that!
I've got an idea that may be bodgeable, will try that first!
Ta.
Posted : 18/11/2020 5:59 pm
Buy one of these - https://www.tftuned.com/i-spec-ev-adapter/p3899 or alternatively the MT500IL lever Shimano do is pretty damned decent and not expensive (if you can use the bonty one elsewhere).
Posted : 18/11/2020 7:39 pm
Does that adapter not go the wrong way (attaches to an EV brake lever?)
I had the same problem as the OP and treated myself to a One-Up lever instead.
Posted : 18/11/2020 7:45 pm
He has 6100 brakes, which are EV.
Posted : 18/11/2020 8:32 pm
Deleted
Posted : 19/11/2020 10:03 am
