HT2 CRANK PLUGS - t...
HT2 CRANK PLUGS - to use the hole as storage
[#12478636]
Anyone make them? Like a fork cork but for bits and bobs
Posted : 27/07/2022 6:23 pm
I've seen tools and things designed to go in them but never a plug. It would need to be very sturdy and very waterproof (at both ends) to inspire me to use it mind.
Also how much are you likely to fit in there?
Posted : 27/07/2022 6:29 pm
 Aidy
But you'd have to carry an allen key and the pre-load tool to be able get into it?
The things you'd need to get into it seem like they'd take up more space than the things you'd be able to store in it.
Posted : 27/07/2022 6:33 pm
But you’d have to carry an allen key and the pre-load tool to be able get into it?
@aidy I'm guessing you go in from the other side 😉
Posted : 27/07/2022 6:36 pm
 Aidy
Which HT2 cranks are open on the drive side?
Posted : 27/07/2022 6:37 pm
So far as I can think, all of them.
Posted : 27/07/2022 6:45 pm
All the mtb ones at any rate.
The magnetic ones are a good idea but the knockoffs (at least) are crap and don't stay put. I'd rather thread something into the drive side but that obviously comes with warranty issues. Alternatively you could make a replacement preload cap that the accessory screws into. Hmm...
Posted : 27/07/2022 6:49 pm
 Aidy
Oh. Yeah - total brain fart, head was in roadie space.
I’d rather thread something into the drive side but that obviously comes with warranty issues.
I'd probably go for a solution like the granite steerer one, a "bolt" from the pre-load on the nds and threaded capsule of some sort inserted from the ds and screwed onto/into the pre-loader.
Posted : 27/07/2022 6:53 pm
Not exactly cheap but I’ve been using one of these for a few years now and like it very much.
A multi tool, a chain breaker and a spare link all stuffed inside the crank axle.
Posted : 27/07/2022 6:55 pm
Just for little bits like quick links
Posted : 27/07/2022 7:13 pm
The Mariposa tubeless tyre plug goes in there and fills it well.
Before that I used to store zipties in there folded back on themselves.
Posted : 27/07/2022 7:21 pm
Zip ties work well, so could you tape chain links to zip ties and put them in that way?
Posted : 27/07/2022 9:56 pm
The other thing to put in there - or even use to plug it is Moto foam. Weighs **** all, stops mud collecting. I stick it all over the bike in winter.
Posted : 28/07/2022 9:14 am
All In multi tool uses a magnet I think. Can you buy just the circular magnets?
Posted : 28/07/2022 10:03 am
I've had a Maxalami twister tubeless tool and spare worms in my axle for a couple of years now, hasn't moved and convenient when needed (which it's not been yet!). Wouldn't want anything that's too faffy to take in or out though.
Posted : 28/07/2022 10:35 am
Those who have things stashed there - plastic stuff excepted obviously - is it not rusted beyond use by now?
Posted : 28/07/2022 10:38 am
Those who have things stashed there – plastic stuff excepted obviously – is it not rusted beyond use by now?
On the Giant set the only thing that shows rust is the magnetic ring that holds it all in place. The tool is usually damp when I pull it out but I guess it must be finished in some way that doesn’t rust.
Posted : 28/07/2022 11:12 am
I had a magnetic multi-tool that I thought was brilliant - so convenient. However, it did rust after a couple of weeks and I wouldn't go that route again.
I have a Granite puncture plug kit that lives in my crank. Has stayed in so far.
Posted : 28/07/2022 12:07 pm
I like to keep a frankfurter in mine for an in-ride snack. I plug in the bread roll to stop it falling out.
Posted : 28/07/2022 2:31 pm
appltn
I never knew such a thing existed, looks like a great little product.
Posted : 28/07/2022 2:51 pm
I've got a granite chain tool in mine.
Posted : 29/07/2022 5:10 am
