How much more effec...
[Closed] How much more effecient are SPD's compared to flats?
http://www.rivbike.com/article/clothing/the_shoes_ruse
Posted : 28/05/2010 10:02 am
Macavity - Member
I started reading this then abruptly stopped when the guy started talking about WEARING SANDALS AND SOCKS - he is obviously a wrongun
Posted : 28/05/2010 10:27 am
With efficiency being a ratio of output/input they are both exactly as efficient as each other. If you start pulling up on the pedals with spds then you are putting more in so will obviously get more out.
Like where you're going, but have to interject - your pully-uppy muscles are not as efficient (they don't translate input energy to output force as well as your pushy-downy muscles) so overall your efficiency drops, but your power output increases. However, as we are more like lots of little batteries (muscles with stores of fuels) the ability to occasionally change muscle groups to a rested one for a bit (short uphill sprint, share the load between 2 groups instead of 1) means you can recover from that hill quicker and keep going longer. IMO.
I find myself in a pickle with this. I've been riding a combo of the two on different bikes for a few months now. As with Aiden (think I spelled it right) - over really rough stuff I find the spds easier to control the bike - I don't bounce off pedals, I have more fine control and if I get stuck in a pedal/wheel positition/root/rock that means I don't normally have enough power to get over it with just one foots worth of torque, I can bring in the pull-up to help out.
But, I can't jump for toffee on spds because it encourages bad technique for me.
I also find I struggle to "go light" over rock gardens on flats.
Posted : 28/05/2010 10:39 am
not sure about efficiency as i cant be arsed to work it out.
but i can confirm than on an mtb... flats are 89% better than clips.
Posted : 28/05/2010 10:43 am
the push muscle in your leg has to be able to lift your entire body mass, the pull one only needs to lift one leg, so the strength ratio is likely to be ~ 8:1 unless you do a LOT of work developing the puller...
Posted : 28/05/2010 10:50 am
Yep, but it is additive, as we discussed in the thread the other week. Bear in mind that each leg is near 1/4 of your body weight and that the muscle used to bring your thigh up to your chest (also used to pull up on pedals) is the same one used to let you sit upright (lifting half your body weight with ease on a regular basis) and there's a few other complicating factors in there. Oh, and of course if you actually use it regularly they get stronger 😀
Posted : 28/05/2010 11:01 am
yeah, but I also suggested the limit isn't muscular strength but the rate at which your body can supply them with oxygen and glucose (apart from sprinting)
Posted : 28/05/2010 11:13 am
Hamstrings and quads are about the same strength. You all appear to be forgetting about eccentric muscle work....
Posted : 28/05/2010 11:17 am
Yes, but we rarely operate at our absolute maximum throughout the whole ride - thats what I'm saying, if it was in use 100% of the time as "normal" operation then it would be less effective, but as it can be used in bursts it can either increase your power output for medium terms or or increase your duration by sharing load at times. MTBing, IME, is rarely about sitting at your cardio max all the time, it;s usually a mix, and when not at your cardio max you can use your muscles and their own little gyco stores to help out.
Of course I don't know the exact details of how it works, thats not my job, but I know it does work and I notice a big difference in performance on the same trail from one day to the next when swapping pedals.
Posted : 28/05/2010 11:36 am
Without more thought into the matter, I don't think they have to be equal strength even considering eccentric work - my triceps are not even close to my bicep strength.
Posted : 28/05/2010 11:37 am
 GEDA
Why am I even reading this?
Posted : 28/05/2010 11:55 am
 jonb
Maybe the only way to settle this is in an experiment. Some one do a loop in spds and a loop in flats. See if you're faster on spds.
Posted : 28/05/2010 11:57 am
CK - you dont walk on you arms though do you.
Posted : 28/05/2010 11:58 am
Much more efficient when you need to bunnyhop
Posted : 28/05/2010 12:02 pm
I prefer SPDs cos it keeps my feet attached to the pedals on the rough stuff.
And I can't tie my laces so the velcro is ideal 😆
Posted : 28/05/2010 12:05 pm
 nonk
In my opinion it works like this..those who ride flats hate spds because they are pants when the use em.
Those who ride spds hate flats because they are pants when the use them.
those who can use both competently dont seem to care what you use.
Posted : 28/05/2010 12:16 pm
Probably true that. I'm too scared to DH clipped in, and kept falling off on slow techy climbs 😮
I would love to see a comparison of a thin, flat pedal, with sticky thin soles, vs some SPDs with SPD shoes. I think they would be much closer in efficiency than they used to be.
Posted : 28/05/2010 12:24 pm
how can I forget something you just invented ?
that soon gets used up
it's impossible to do a blind test and expectations interfere...
the people who bunnyhop over large objects use flats. I can do it too 🙂
Posted : 28/05/2010 12:26 pm
No ones mentioned this but I find SPD are much better for standing up on a full suspension bikes.
I've been ridding swinley on both flats and spd recently and there are lots of (very) short sharp climbs. If I try to sprint up a hill standing up, on a full suspension bike with flats, the bike feels very mushy and alot of power is lost to the suspension.
I dont notice this effect so much when wearing spd's because you can balance the downstroke on one leg with the upstroke on the other leg leading to less pedal bob.
I like both SPD's and Flats but in my opinion flats are a definite no-no on cross country full suspension bikes.
Posted : 28/05/2010 12:42 pm
I can and do ride both.
rarely ride clipped in now as on balance I prefer flats.
Posted : 28/05/2010 12:47 pm
At least you can wear normal bloody shoes
Posted : 28/05/2010 12:57 pm
thats one of several reasons for running flats on all my bikes.
Posted : 28/05/2010 1:00 pm
I would never try that 🙂
I rode that way for 10 years...
Posted : 28/05/2010 1:03 pm
Flats all the way for me.
If the xx% more efficient, then presumbaly i'm xx% fitter than all my riding budies on SPDs?? either that or they just aren't trying!
Posted : 28/05/2010 1:05 pm
having seen someone fall off last week at 2mph and get a spiral fracture of the upper arm due to brand new cleats (which I'd seen him adjust at least 3 times) not releasing I'm dubious of the advantages of spuds!
Posted : 28/05/2010 1:17 pm
SPDs are a lot like Computers, Wii, Playstation, Txt'ing etc.
Old people just don't get it.
Posted : 28/05/2010 2:04 pm
I just got my secretary to type this for me...
Posted : 28/05/2010 2:05 pm
mmm your legs go in a 360 motion.
With flats you can only work half of that.
Even with the dead spot, it would be easy to see how SPD work more efficiently.
Posted : 28/05/2010 3:01 pm
I started this game 21/2 years ago and at this point I hadnt ridden a bike for 15 years. I went straight to SPDs after one ride when I slipped off the pedal and hurt myself on the chainring.
I really fancy trying flats (too many hilarious slow speed topples- and landing on my bum still attatched to the bike)
Will I have to learn all over again? I am just getting the confidence to do little jumps; I dont want to loose it 🙂
Posted : 28/05/2010 3:28 pm
So you just do more work with SPDs (because you're pushing/pulling the entire 360 degrees)? That isn't the same thing as being more efficient - that's just doing more work.
Posted : 28/05/2010 3:38 pm
but to make up for that, most of us have two 🙂
Posted : 28/05/2010 3:40 pm
Horses for courses, innit!
SPDs undoubtedly allow me (Stress the "ME" there!) to transfer more power more efficiantly from the pedals. Fact. End of. I do pull up quite hard, to the point where I've been known to pull out of a pedal when going uphill hard. So therefore I'm clearly using them to their best advantage, and in general I have a smooth, circular pedalling motion (Rather than just stomping on the pedals and bobbing all around the place.
But
A LOT of the advantage comes from the stiffer soled shoes. I always used to use a basic trail shoe, until I used a basic racy-type shoe for the Trans Wales. There's a noticeable lack of flex and improvement in power transfer. It's not massive but it is there.
So
When I wanted to try some new technical stuff locally, I took the SPDs off my bike and fitted flats (I can use both with ease) and rode up there. The first decent hill I came to I had to push up, when I normally ride up easily (There's nowt round here I can't clean) Why? Because I was on my SINGLESPEED and I just couldn't get quite enough power down with softer shoes on.
Therefore
I conclude the PEDALS are no different. A bit of metal and a bearing, whichever way you look at it. It's just the way I USE THEM that's more or less efficiant. i.e. I can pull up and use stiffer shoes on SPDs, I wear softer shoes on flats and can't pull up.
That's it.
Posted : 28/05/2010 3:55 pm
Poddy has [b]better pedalling technique than you do[/b], and all you haters can suck his balls. 🙂 😉
Posted : 28/05/2010 4:08 pm
I'm not even keen on the pushing down part 🙁
Posted : 28/05/2010 4:11 pm
Poddy has better pedalling technique than you do, and all you haters can suck his balls
Not what I said, or meant. But thanks for the compliment! 😀
I believe mine is square but I can't get the cranks to fit it 🙁 What mastermind invented unsmooth, uncircular pedalling ? I christen it Poddotosh 🙂
Posted : 28/05/2010 4:15 pm
Come now simon, even you know that it dosn't describe the physical shape your feet trace as you pedal, but where you apply torque and where you don't.
Posted : 28/05/2010 4:21 pm
thanks for that wonderful diagram of a foot 🙂
I also love the mixture of Imperial and SI units 🙂 - though lb-foot is strangely appropriate 🙂
Posted : 28/05/2010 4:23 pm
Other shapes are availible.
Posted : 28/05/2010 4:25 pm
If I understand that diagram correctly, the user either is not using spds or is deriving very little benefit from them. Which is it? 🙂
Posted : 28/05/2010 4:26 pm
Dunno, it was the only small pic of a spin scan I could find with a quick google. The others were huge.
I seem to recall some interesting ones from q rotor users in last years TdF, but I don't care enough to find them.
Posted : 28/05/2010 4:28 pm
I think it reflects the fact that you cannot pull up very much... with flats the left hand lobe would be absent and the right one tangent to the centre.
Posted : 28/05/2010 4:29 pm
I believe mine is square but I can't get the cranks to fit it What mastermind invented unsmooth, uncircular pedalling ? I christen it Poddotosh
You know what I mean even though you make out you don't, but of course it's impossible to argue with you once you have a bee in your bonnet, isn't it? 😉
But I'll have a shot anyway...
Unsmooth - People who bob up and down all over the place and mash 'hard' on the pedals (It really shows on FS bikes) without going any faster than those sitting nice and still and pedalling smoothly right next to them.
Smooth - The others I mentioned above, right next to the unsmooth ones!
There's a definate technique to pedalling smoothly. I'm OK, not brilliant, and if I think about it and try hard, I get a bit better. Ask a roadie, they know all about that sort of stuff. 😀
Posted : 28/05/2010 4:36 pm
When I'm pedalling in the saddle just mooching along I don't pull up much. If I'm stood up on the pedals riding up a steep hill, partic if I'm on a SS, I tend to *just* pull up, the only push down component is my weight on the retunring leg. But I've done this enough that my 'pull up' muscles are well developed. It seems pretty sucessful, I can ride up absurdly steep stuff anyway.
The only time I pedal in smooth circles (or, for simon, try to apply torque evenly throughout the stroke) is during road sprints and TT's. I try to avoid those though.
Posted : 28/05/2010 4:37 pm
That's the best way I've ever seen it described ADH, thankyou. 🙂
Posted : 28/05/2010 4:43 pm
Page 2 / 4
