How long can you go...
[Closed] How long can you go with forks?
[#1651334]
I'm currently running an old (1996) Specialized M2 Stumpy frame which originally came with 80mm travel Judy's, I've since upgraded these to Pace 100mm RC38LTs. The increase in travel didn't give a significant change to the geometry, just enough to slacken things off slightly from it's hardcore XC breeding.
My question is this:
How long forks do you think I could get away with and what would be the limiting factor? Would it be the headtube strength or the sloppy handling that would be the limiting factor. I don't want to go crazy, maybe fit some 120 or 130mm forks, but should I really be looking at a new frame?
Posted : 28/05/2010 9:29 am
I would say the bigger risk is the type of riding that 130mm forks will encourage!
If you think you need more than 100mm travel, you need a new frame.
That, and it'll likely handle like a barge until the head tube fails! Are you sure they were 80mm originally? A 1996 would surely have had 63mm?
Posted : 28/05/2010 9:31 am
You won't know if strength is a limiting factor until it breaks.
As for handling it sounds like you could take more OK. Modern bikes are slacker in any event.
Posted : 28/05/2010 9:32 am
I used to have the same frame and I also had 100mm forks on it. They handled well downhill but the front wheel tended to lift on steep granny ring climbs.
TBH I don't think longer than 100mm will handle well - I don't think the bike will climb at all well. And I'd also be worried that the frame would fail. You've got a lightweight XC frame - stick with lightweight XC forks.
Posted : 28/05/2010 9:40 am
You can always shove your seat forward.
Whether strength is a limiting factor depends on too many factors.
Posted : 28/05/2010 9:43 am
Actually, you could well be right there.
Oh well, it looks like I'll be sticking to the 100m forks, and will have to add another steed to the garage for a longer travel more hardcore HT - what a bummer!
Posted : 28/05/2010 9:45 am
