How easy is... disc...
[Closed] How easy is... disc brake help please?
[#4014326]
Morning
I'd like to swap my M4 callipers around IS to the back and post to the front as I've got a pair of post mount forks I want to fit.
The hoses are Goodridge, so is it just a case of draining the fluid then unbolting the hoses at the calliper end - reconnecting / refilling / bleeding or will I need to replace some other bits like seals etc?
I quite fancy learning how to do this so all tips would be welcome.
Thanks in advance
Posted : 28/05/2012 10:25 am
Pretty much - you sure you've got the correct calper/rotor sizes (or adaptors?) Switching IS front to back drops 20mm in rotor size.
Posted : 28/05/2012 10:29 am
Boxelder both ends are 180mm
The forks are Thors so the calliper bolts straight on so I won't need an adaptor on them and I can use the adapter form the front which is an IS to IS +20 for the rear.
I't more recconneting which I'm not sure on.
Posted : 28/05/2012 10:35 am
